Sponsored by: Auxito
Scan Guage II
Old Sep 14, 2008 | 11:00 AM
DJPRacer58's Avatar
DJPRacer58
Scan Guage II
anyone on hear have on of these. i just got one was was wondering how much HP they are getting. i got a 5.4L and im getting HP readings of 280 and tq of 310-315. my truck is a 99 and i thought these readings are more then the motor is supposed to make from factory. anyone else with these guages getting readings like this?
l
Old Sep 14, 2008 | 12:18 PM
xtrford's Avatar
xtrford
I peaked at 285hp at around 5000 rpm on the highway, and around 360tq when I was 4X4 in the mud ....but I highly doubt these are accurate because it reallies more on math rather than load. Only a dyno will give you accure hp/tq readings and I would say both are vehicles will be lower than what the scangaugeII says.
Old Sep 14, 2008 | 04:56 PM
firefighter1416's Avatar
firefighter1416
i just ordered one do they seem fairly accurate on the real time gas mileage
Old Sep 14, 2008 | 05:09 PM
DJPRacer58's Avatar
DJPRacer58
yea the gas mileage seem right. xrtford, thanks but you have a chip and stuff done to your truck, that might be why yours are higher. my truck is stock that i know of. what readings are ppl with stock trucks getting.
Old Sep 14, 2008 | 07:15 PM
galaxie641's Avatar
galaxie641
Mine is spot on, on the gas mileage. Interesting that the II's give you hp/tq numbers. Do you have to do an elapsed time or something to get them?
Old Sep 14, 2008 | 08:17 PM
xtrford's Avatar
xtrford
The new scangaugeII comes with Xgauge software which allows to add gauges the unit doesn't come with such as hp and trq. The page gives a brief explanation on how it calculates the math.
http://www.giffordautomotive.com/ima...augeCoding.pdf
Here is a page which gives you the optional gauges that are available for the Xgauge software. *Note* not all gauges will work with our gen of trucks like torque converter line pressure and feul pressure because the PCM doesn't monitor these parameters.
http://www.scangauge.com/support/pdfs/XGAUGE.pdf
Old Sep 14, 2008 | 08:24 PM
xtrford's Avatar
xtrford
Yup...it is chipped and all that mumbo jumbo. My torque/horsepower suffered when I went from just under 33's to 34"+ tires...and so did the mpg's. I hope to install 4:56's soon to rectify that problem.
