tail gate hardware
Old Sep 14, 2008 | 10:13 AM
johaner78's Avatar
johaner78
tail gate hardware
I know this is a paint / body forum question and it's posted there but no responses yet so I'll ask the experts here.
The tailgate support straps (the ones that fold up when you shut the tailgate) and the latches get some surface rust on them after about 30+ years. I've used some really worn out sand to clean them up (almost like using a soda blaster). I want them to look very similar to OEM hardware and they do now that they are cleaned up. Question - how do I keep them lookins this way for a LONG time. I've thought about clear coating but that makes them too shiny. What about just coatin them with WD40? any other suggestions? I don't want them painted as paint chips off when you close the tailgate.
Thanks
Old Sep 14, 2008 | 11:49 AM
4x4 Bart's Avatar
4x4 Bart
You might try "Fluid Film" it leaves a better coating than WD. You can also coat bare metal with "Linseed Oil" for some protection but I don't know how shiny it is
Old Sep 14, 2008 | 11:52 AM
77f2504by4's Avatar
77f2504by4
couldnt you clearcoat them then scuff up the clear with a 3000 grit paper to knock down the shine?
Old Sep 14, 2008 | 04:50 PM
rickh51's Avatar
rickh51
Check out The Eastwood Company. They have all kinds of coatings and plating systems available. I'm sure you can find something there that will work for you. Eastwood Company: Auto Tools, Body Repair, Classic Car Restoration, House of Kolor Paint, Powder Coating
Old Sep 14, 2008 | 07:12 PM
johaner78's Avatar
johaner78
Thanks guys for the input. really trying to stay away from paint because it chips off. a oily coating is kinda what i'm after but something that doesn't wash off and won't collect dust. Kinda limits my products, huh? lol
Old Sep 14, 2008 | 07:24 PM
johaner78's Avatar
johaner78
4x4 Bart - looked at Fluid Films website - looks kinda enticing. You have evidently used this product? Does it leave a thick waxy coating that is pretty evident or is it more like a thin oil like wd40 or other petro solvents?
Old Sep 14, 2008 | 07:26 PM
jcduerr's Avatar
jcduerr
mine have been painted for 3 years and only parts that have no paint are where they scissor together, quick blast every now and then and back to new
Old Sep 14, 2008 | 07:52 PM
77f2504by4's Avatar
77f2504by4
mine are bare metal and have yet to rust, 'bout the only things on the truck not rusted!
Old Sep 14, 2008 | 08:18 PM
johaner78's Avatar
johaner78
77f2504by4 - are they original or have you somehow used an abrasive media (wire wheel, sandpaper, media blasting) to clean them up? I'm thinking that since i've had to use some media blasting to get them cleaned up to a uniform color that the "protective rust coating" if there ever was such a thing on these parts, is peeled off and they will rust eventually. All body panels contain an E coat and once you grind that off, rust will form. I'm wondering if that's what will happen with these supports. Let me know 77f2504by4.
Old Sep 14, 2008 | 08:41 PM
77f2504by4's Avatar
77f2504by4
i never touched them, as long as i've had the truck theve been there. i've had it 5 years now. i'm thinking they are galvanized.
heres a thought, what about using a product like por15 or rust bullet? they are thicker and tougher than regular paint...
Old Sep 14, 2008 | 08:45 PM
jcduerr's Avatar
jcduerr
but with it being thicker will it hinder closing???
Old Sep 14, 2008 | 09:10 PM
BrentNewland's Avatar
BrentNewland
Aren't both of those enamel products (they dry into a very hard substance)?
Old Sep 14, 2008 | 09:37 PM
johaner78's Avatar
johaner78
thanks for the suggestions but i'm staying away from paint. i like 4x4barts idea the best so far to try and retain original look. paint =
Old Sep 15, 2008 | 10:50 AM
NOCO77's Avatar
NOCO77
I media-blasted mine and had them clear Cadmium plated. Powder coating is also available in Low-gloss, satin or flat clear.
Old Sep 15, 2008 | 07:04 PM
4x4 Bart's Avatar
4x4 Bart
Fluid Film is thin and clear like wd-40 and lasts for a good while, you can respray it periodically, the only draw back, it smells funky until it drys good.
