Offroad & 4x4
Manual Hubs
Old Sep 15, 2002 | 08:48 PM
MustangGT221's Avatar
MustangGT221
Manual Hubs
Old Sep 18, 2002 | 12:41 AM
HD61cuin's Avatar
HD61cuin
Manual Hubs
I have an 86 F250 with manual locking hubs. Is a good way to check them, lock the hub and jack up that wheel and attempt to turn? I still have the factory hubs and the left front hub lever is slightly cracked. Second of all, is there a specific hub that I need to purchase for my application, I have no idea what axles I have.
So:
how to check
how to order new ones
Will
Alsip, IL
86 F250 4x4 351W
97 Explorer XLT 4x4 4.0 SOHC
99 Jeep Sahara 4x4 4.0 I-6
Old Sep 18, 2002 | 03:03 AM
Big F250's Avatar
Big F250
Manual Hubs
The front axle in your truck is either the light duty dana44HD-IFS which has 19 splines or the heavy duty Dana 50-IFS which has 30 splines. If your hubs are bad, count the splines on your axles and see what axle you have.If it has 19 splines order dana 44 hubs; if it has 30 splines, order dana 60 hubs (the dana 50 uses dana 60 everything from the spindle out)
Old Sep 18, 2002 | 03:14 PM
MustangGT221
Manual Hubs
If you have a supercab, it's a dana 50. Also, if it has an 8600lbs GVWR then it's a D50 and has a full floating 10.25 out back. That GVWR is listed on the sticker on the door jam.
Primary rig is Green Thunder:
95' F-150 XLT 4x4, 302, 5 spd, MSD 6A, Flowmaster American Thunder Exhaust, Sunroof, Clear corners w/ Diamond headlights, CD player with 2 10" subs and some 32" BFG Muds .
That's it for mods now, saving for a Stang. Check out my Gallery for a look-see.
Old Sep 18, 2002 | 06:51 PM
HD61cuin's Avatar
HD61cuin
Manual Hubs
I have 8 lugs on front and rear axles. The rear has an additional 6 or so bolts on the rear center axle cover? I have not looked at my sticker lately. I am having the rear axle seals replaced as well as a rear brake job. I jacked up the front end and locked each hub one at a time. They rotated the axle and unlocked properly.
Will
Alsip, IL
86 F250 4x4 351W
Old Sep 18, 2002 | 08:34 PM
HD61cuin's Avatar
HD61cuin
Manual Hubs
Ok I have the 8600 GVWR so that means that I have the heavy duty axles. That is a Dana 50 in front and 10.25 full floater rear? What other things that I don't know about are included in the 8600 GVWR package? I dont know what Transfercase I have, I think it is the Borg Warner but I am not sure. It is manually activated by lever on the floor.
Thanks for the response.
Will
Alsip, IL
86 F250 4x4 351W
Old Sep 19, 2002 | 09:47 AM
Cope's Avatar
Cope
Manual Hubs
Probably a BW-1345
-Cope
97 F-350 PSD ZF 5 Speed 4x4
Old Sep 19, 2002 | 12:30 PM
Big F250's Avatar
Big F250
Manual Hubs
HD61cuin, I have the same truck as you 86 F250 8600 GVWR. Mine has the NP208 transfer case. It has a circular green tag that says NP 208 on it. I'm not sure how to identify the BW case.
Old Sep 19, 2002 | 06:33 PM
MustangGT221
Manual Hubs
My borg warner TC says what it is right on it. Mines a 13-56 though. The rear axle is a full floating sterling 10.25" axle, the front is a dana 50. Doesn't get any more complicated then that.
Old Sep 19, 2002 | 07:40 PM
HD61cuin's Avatar
HD61cuin
Manual Hubs
Well if it comes down to it, I will be able to find out my transfer case when the time comes.
Will
Alsip, IL
86 F250 4x4 351W
