Offroad & 4x4
suspension lift
Old Sep 3, 2002 | 07:07 PM
MustangGT221's Avatar
MustangGT221
suspension lift
Old Sep 22, 2002 | 09:53 PM
bronco351's Avatar
bronco351
suspension lift
Hi my 1990 Ford bronco currenlty has a 4" lift. Rancho lift kit with radius arms and everything. My question is can I make my truck bigger by adding leaf springs and coil spacers. Is that the same thing as a body lift??
Old Sep 22, 2002 | 10:11 PM
MustangGT221
suspension lift
A body lift uses bushings on every body mount, and actually lifts the body off the frame. The 4" kit you have, is called a suspension lift, and so are the spacers you mentioned and the leaf springs you mentioned. The best way to do this, is to get 6" springs, I think the rancho kit has axle pivot brackets with another hole for the 6" right? Drop it down, and get some lift leaf springs from skyjacer and you're good to go. If you want to go the cheap crappy way, get the spacers, drop the axle pivot bolts down to the 6" hole, and put add-a-leafs in the rear, it'll stiffen your ride though, thats why a whole new lift leaf spring is the better option, it won't ruin the ride.
Primary rig is Green Thunder:
95' F-150 XLT 4x4, 302, 5 spd, MSD 6A, Flowmaster American Thunder Exhaust, Sunroof, Clear corners w/ Diamond headlights, CD player with 2 10" subs and some 32" BFG Muds .
That's it for mods now, saving for a Stang. Check out my Gallery for a look-see.
Old Sep 23, 2002 | 01:45 AM
bronco351's Avatar
bronco351
suspension lift
[updated:LAST EDITED ON 23-Sep-02 AT 02:50 AM (EST)]One more question. Am I going to need bigger shocks, Longer drive shaft, longer brake lines. By the way thanks a lot for all the help!!!
Old Sep 23, 2002 | 03:15 PM
MustangGT221
suspension lift
I assume that you mean bigger as in higher? I believe that on a 6" lift, you need to lengthen the driveshafts on a bronco because of the short wheelbase, and you might possibly have a problem with the front crossmember on the transfer case because of the driveshaft angles. So either wait for someone here to get a definite answer, or head over to the bronco forum and ask there. You will need longer shocks, and brake lines you need as well I believe.
95' F-150 XLT 4x4, 302, 5 spd, MSD 6A, Flowmaster Exhaust, Sunroof, Clear corners w/ Diamond headlights, CD player with 2 10" subs and some 32" BFG Muds .
Thats it for now, saving for a stang. Check out my Gallery for a look-see.
Justin
