89 f250 no spark
Fuel pump running for 4 seconds is a very long time for the pump to run, it should only run for one second.
That said the computer can not stop the coil from firing only change the time that it fires.
Pull out the SPOUT out and you cut the link to the computer and the Ignition system.
If no spark with the SPOUT out it can only be the Distributor/PIP sensor/TFI Module combination and Coil that you have changed plus the wiring.
A lot of the time this turns out to be a bad plug that plugs onto the Coil, check this plug very closely. You should have steady power on one side of the coil and the test light should flash on the other side while cranking.
moodyfam9
12-03-2012 08:05 PM
apalo187
Escape & Escape Hybrid
05-05-2010 08:56 AM
