Brakes!!!
Old Sep 13, 2008 | 05:49 PM
Timon5435's Avatar
Timon5435
Brakes!!!
Time to replace front Brakes. 75K miles and will need new rotors and brake pads. Any issues with going with a bigger rotor and what problems that may bring up. Want something that will last not concerned about $$$
Thanks for your help.
Old Sep 13, 2008 | 05:55 PM
weekendwarriorfsw32's Avatar
weekendwarriorfsw32
Master of Strokes
I love my Hawk pads and Power slot rotors
Old Sep 13, 2008 | 05:58 PM
FordxFour's Avatar
FordxFour
You can also use the Search this Forum button and enter brakes/rotors and read what others have discussed and done. A wealth of info...
Old Sep 13, 2008 | 06:28 PM
ReAX's Avatar
ReAX
All of the big rotor kits I've seen have been for the 2wd. Baer makes some great setups, but they are performance sets so they may not last as long as cheaper pads. For Baer, entry level big brake kits are $1200 (front only) and if they have a 6 piston caliper you can expect it run around $4k.
Other brands you might consider. SSBC has some calipers that are quite nice. DBA (disc brakes of australia) has a unique vent design as well as two piece rotors. Performance Friction would be my choice, their two piece rotors with their pads and SSBC force 10 calipers. If I hit the lottery, that would be the setup I would have.
Old Sep 14, 2008 | 08:23 AM
1's Avatar
Bigger rotor setups are probably WAY more then you want to spend.
I am very happy with my powerslot cryo's and hawk pads. I got in a lil car chase after someone hit and ran my truck and was in ABS from 40-5mph countless times for a few minutes and ZERO fade, and no "warped" rotors. I'm sold!
