1978 - 1996 Big Bronco
carb problem
Old Sep 13, 2008 | 01:04 PM
yoyobronco's Avatar
yoyobronco
carb problem
hy every one i ave a problem with my carb mabe some one already ask this . the screw in the carb is to blow more gaz in ? .
there's the question( to blow less gaz in what i ave to do turn clock whiz or conter clock whiz ) tank's for the answer
Old Sep 13, 2008 | 08:18 PM
79FordBlake's Avatar
79FordBlake
Counter clockwise(makes it richer, more fuel). Clockwise(makes it leaner, less fuel). Best time to adjust it is when the engine is up to operating temp.
Old Sep 13, 2008 | 10:33 PM
yoyobronco's Avatar
yoyobronco
ok but my heat guage dont work for now . it's the next thing i will fix on it.
i ave an other thing is a 4bbl but only 2 bbl work on becose he ave only one gaz line how go's in , becose of that the carb go black every time i clean it the last time .
and for what i see when i check , to mutch gaz for the air mix i will mabe ave to go see for a ford mecanic to make the tune up . a freind said to me it was a automatique carb transform in a manuel mabe is the problem . but big tank's for your help this will make the deal for now , the next ride will be less expensive becose today he cost me the half of the gaz tank . tank's again
