Offroad & 4x4
4wd front end noise
Old Sep 26, 2002 | 12:05 PM
1fast68's Avatar
1fast68
4wd front end noise
Old Sep 27, 2002 | 09:51 AM
bigbird1's Avatar
bigbird1
4wd front end noise
When I"m in 4wd I hear a noise like something vibrating
or humming. Is this a normal noise in 4wd?
Old Sep 27, 2002 | 04:50 PM
Sam Wactor's Avatar
Sam Wactor
4wd front end noise
How fast are you driving with the front end locked in. If you are going 30 mph or so, I think it's normal.
Old Sep 27, 2002 | 05:25 PM
Djoffroad's Avatar
Djoffroad
4wd front end noise
I would start by checking the condition of the front drive line and it's ujoints. Then I would check the knuckle and ball joints. Remove the diff cover, inspect the gears and the pold gear oil for metal shavings. If all seems normal, check the wheel and needle bearings.
Silly rabbit. Jeeps are for chicks!!
"If you're not getting stuck, you're not trying"
76 F100
Old Sep 27, 2002 | 08:13 PM
MustangGT221's Avatar
MustangGT221
4wd front end noise
If it's an 80-96 there is no diff cover, you'd have to take the whole TTB out.
Primary rig is Green Thunder:
95' F-150 XLT 4x4, 302, 5 spd, MSD 6A, Flowmaster Exhaust, Sunroof, Clear corners w/ Diamond headlights, CD player with 2 10" subs and some 32" BFG Muds .
Thats it for now, saving for a stang. Check out my Gallery for a look-see.
Justin
