Aerostar Ford Aerostar
No heat
Old Sep 12, 2008 | 03:21 PM
MFJ's Avatar
MFJ
No heat
Last year the heat stopped working. 93 2wd 4.0l, rear heat/AC. Temp gauge fluctuates between N and L quite a bit. Coolant is full, but does lose some. Goes up to L, then drops quickly to N, then slowly back up. AC hasn't worked for a while.
Time for a thermostat? New heater core? Doesn't seem to be coolant in the oil. It is now the spare vehicle, but winter is coming. Don't feel like scraping the inside of the windshield anymore.
Old Sep 12, 2008 | 04:29 PM
Bax2008's Avatar
Bax2008
Sounds like a t-stat to me. Sounds like it's stuck open.
Had that happen to me last year.
Bought one of those "Fail Open" t-stats. MISTAKE!
It did. I froze.
Bax
Old Sep 12, 2008 | 07:04 PM
xlt4wd90's Avatar
xlt4wd90
Is that a symptom of a stuck open t-stat? Mine started doing that right after I did a major flush. I always thought it was air that I could not purge from the system. My previous experience with a stuck open t-stat prevented the engine (and heater) from warming up in the winter. This one does not.
Old Sep 13, 2008 | 10:56 AM
MFJ's Avatar
MFJ
Drove it to work today, then got out the thermometer at home.
Not sure what it should be. About 70 or so outside, I think it should get warmer.
The temp gauge on the dash moves around fine.
On the way home it crept up past the L, then dropped to O.
I'll try to answer any other questions. This has me stumped.
Old Sep 13, 2008 | 12:29 PM
Bax2008's Avatar
Bax2008
You mentioned rapid temp fluctuations in your OP.
That's usually a symptom of a bad t-stat.
When mine went bad, when the vehicle was stopped, the temp would quickly rise to normal. When I started driving, it would bottom out to the cold end.
Stuck open t-stat + steady cold air-flow = serious overcooling.
Old Sep 13, 2008 | 12:57 PM
MFJ's Avatar
MFJ
How much of a pain is the T-stat on these? I hope it is not too bad.
The temp gauge moves around, a lot. My Sable and Windstar gauges are both pretty steady, and have heat (part of why the Windstar was bought, along with a working side door ).
Old Sep 13, 2008 | 01:25 PM
xlt4wd90's Avatar
xlt4wd90
Like anything on an Aerostar engine, the T-stat takes a bit of parts removal to get to. The bolts, especially the lower one on the housing, will require some extensions and flex joints to get to. Be careful of the wire going by that area, as it is for the crank position sensor; some people have damaged it while replacing the T-stat, and the engine won't start afterward.
Old Sep 13, 2008 | 03:47 PM
aerocolorado's Avatar
aerocolorado
Originally Posted by MFJ
... Coolant is full, but does lose some. Goes up to L, then drops quickly to N, then slowly back up.
Also acts like this when air gets in the system. Temp sensor sits at the high point and any air trapped there will cause gauge flucuations like you describe. Hard to get all the air to bleed out. If you are losing coolant, you likely have air in the system.
Old Sep 22, 2008 | 10:59 AM
MFJ's Avatar
MFJ
Got a new radiator cap, and tried to burp the system. Seems to work better now, the temp gauge doesn't swing like it used to. Still in the 70's around here, so I didn't try the heater out yet. While burping the system, a little bit of heat was there, but not like it should be. I'm thinking about taking the rear heat out of the system, less chance for leakage. The hard lines are rusty. The van is not going to be used for passenger haulage anymore for the most part. Gets cool in the back.
At that explains why the cubbyhole fills with water.
Old Sep 22, 2008 | 11:52 AM
Bax2008's Avatar
Bax2008
Are the rocks for ballast in the leaky boat?
Old Sep 24, 2008 | 12:10 AM
MFJ's Avatar
MFJ
Not sure. The wife put those in there, really don't know why...
nm1198
Nov 18, 2016 09:41 AM
c2z4s9
41
Dec 1, 2015 09:56 AM
Mike Parker
Oct 29, 2015 05:47 AM
Mike Parker
Oct 28, 2015 05:15 PM
88grandmarquis
Jul 13, 2010 07:07 PM
