88 460 starting problems
Old Sep 12, 2008 | 10:11 AM
wahlturfcare's Avatar
wahlturfcare
Question 88 460 starting problems
just recently my 88 f350 with a 460fi has started to not want to start well. Sometimes it acts like the battery is week then starts. And other times it just cranks untill i move the cables around. i checked and it is getting fuel and spark each time. I cleaned the batt terminals and cap/rotor.
Note. i did have the starter,etc off last weekend to do a oilpan gasket but ran fine until yesterday(Thursday).
Any sugestions?
Old Sep 12, 2008 | 10:27 AM
subford's Avatar
subford
Replace both battery cables,
Old Sep 12, 2008 | 10:43 AM
wahlturfcare
could they have a broken wire inside the cable? Which parts store sells the ones to fit, or is a junk yard easier?
Old Sep 12, 2008 | 10:44 AM
wahlturfcare
also, i did notice that when i hit the electric lift for the dump bed the trucks batt gauge goes down and the radio quits for a sec.
Old Sep 12, 2008 | 10:56 AM
andym's Avatar
andym
Replace all the battery cables. Any decent parts store will have them. Don't get them from a junkyard.
The plastic casing on the cable breaks down over time and allows moisture into the cable. It corrodes and doesn't conduct enough electricity and you get what you're describing. I would also clean all the cable connections when you do this.
