best oil
Old Sep 11, 2008 | 08:24 PM
crestfallinman's Avatar
crestfallinman
best oil
its that time again and i once again i am unsure on what oil to use
i have ford motorcraft 50/50 synthetic/ conventional in now
should i go to full synthetic or is there a better alternative?
i already know im gettin a motorcraft filter
Old Sep 11, 2008 | 08:31 PM
bwoldschool65's Avatar
bwoldschool65
Personally i like wix filters and pennzoil full synthetic
Old Sep 11, 2008 | 10:15 PM
OldRacerGuy's Avatar
OldRacerGuy
Motorcraft filters and Rotella T 15/40
Old Sep 11, 2008 | 10:18 PM
quaddriver's Avatar
quaddriver
best oil
Im sorta partial to Bertolli extra virgin light....
Old Sep 12, 2008 | 12:14 AM
kell104's Avatar
kell104
valvoline high milage 10w30 motorcraft filter. Some people think the high milage stuff is a gimic and it may be but my truck likes it. Burns about half with it verses regular 10w30
Old Sep 12, 2008 | 12:40 AM
ymeski56's Avatar
ymeski56
Der Postmeister
Ya already got your feet wet, might as well jump in & go Synth. Add a can of Seafoam Engine Treatment just prior to change to remove contaminant build up deposits. Synth. motor oil at 100% is Superior in every way except 1. The physical properties that allow it to perform so well in all other aspects is also the cause of it's 1 short coming, which is limited lubrication of upper engine components at initial start up. So add 1 Qrt. of Lucas Synth. Oil Stabilizer and that will more than make up for that.
Old Sep 12, 2008 | 09:03 AM
Dean88's Avatar
Dean88
Rotella 15 40 and motorcraft filter
Old Sep 12, 2008 | 02:55 PM
themoparkid's Avatar
themoparkid
motorcraft filter and pennzoil 10w40. nuff said. motorcraft oil is junk, IMO.
Old Sep 12, 2008 | 05:11 PM
tdbronco77's Avatar
tdbronco77
I use a motorcraft filter and valvoline 10w-30 premium conventional oil on a 185,000 mile351w. But my truck hates valvoline high milage or anything other semi-sythetic or full synthetic. Anyone run into severe leaks or power loss with synthetic?
Old Sep 12, 2008 | 05:32 PM
Jason Lewis's Avatar
Jason Lewis
I use Valvone 10w30 Motorcraft filter, for the past 10 years no probs !
Change every 3,000 (Give or Take) a few
After 3,000 you can still see threw the oil !
Mileage 130,000
Old Sep 12, 2008 | 11:23 PM
mstngmikegt's Avatar
mstngmikegt
My truck...Valvoline 10W-30 conventional and FL-1A filter...works great. My Mustang...Mobil 1 10W-30 full synthetic and FL-1A..works great too. Mustang has been on synthetic for the 17 years I have owned it and has 107K on it, did head swap about a year ago and stuff inside was like new...beautiful..wouldn't change a thing. Also wouldn't run my truck on it. Has 140K on it, been conventional always and don't need to create leaks that don't exist now (a damp gasket will be a leaky gasket when introduced to synthetic). Have seen it repeatedly along the way in other people's stuff. Also, there is no way I would ever use Seafoam in an engine ever for any reason..fuel maybe but not in oil period but is just my .02 worth. Same deal...based on previous observations.
Old Sep 13, 2008 | 07:35 AM
guitarnik's Avatar
guitarnik
valvoline prem conv motor oil all the way baby straight 30w. wix filter, if its good enough for nascar its good enough for me.
