Aerostar Ford Aerostar
temp control switch
Old Sep 11, 2008 | 01:37 PM
B Dobz's Avatar
B Dobz
temp control switch
The temp control switch on my 96 aerostar is broken and just spins around where online can I get this and is it hard to change,I hope I don`t have to take to much of the dash apart.thanks
Old Sep 11, 2008 | 05:50 PM
96_4wdr's Avatar
96_4wdr
AutoZone.com | Vehicle Selection - Year
junk yard parts emporium or rockauto.com
Old Sep 12, 2008 | 08:40 AM
B Dobz's Avatar
B Dobz
Hell if I can find this thing?any help please.
Old Sep 12, 2008 | 10:03 AM
copper_90680's Avatar
copper_90680
I believe that there is a cable hooked to that ****. The cable opens/closes a blend door to mix hot and cool air to give you the desired temperature.
If that **** is turning freely, that can only mean one thing, the cable assembly is broken. You must open up the front panel first to see what's broken and what's to replace. 96_4wdr is right. That kind of parts is difficult to come by in traditional autopart stores. It's either dealers only or you can try the junkyard.
Good luck
Old Sep 12, 2008 | 10:15 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
This will be a dealer item only, you won't find it at any auto parts store.
FTE has Ford Dealer Parts Department sponsors that give discounts off the actual Ford MSRP.
F39Z18518A .. Temperature Control Cable
MSRP: $29.10 / FTEpartsguy.com price: $20.95
Old Sep 12, 2008 | 11:15 AM
xlt4wd90's Avatar
xlt4wd90
If you can't find the exact replacement part from your local scrap yard or Ford parts dealer, you can try what I did with my 69 Mustang. Parts for them are really hard to come by, so I made replacement cables from a generic steel remote control cable I got at my local Kragen's. The stock controller had 2 plastic jacketed control cables molded to a plastic frame that was screwed onto a bracket near the control cluster, and they all cracked through age.
The new cable has a spiral-wound steel outer jacket, and is much more durable than the stock plastic housings, or whatever you can find from another car at the scrap yard. I had to make a new clamp to hold the two new cables to the bracket that the old cables were screwed to; I used a clamp piece that came with the generic cable kit. I then curled the inner cable ends so they wrapped around the control sticks. They work, and I'm betting that they will out last any plastic parts that I might have gotten.
Old Sep 12, 2008 | 11:36 AM
copper_90680
Or have your wife sitting on the passenger seat, holding that blend door in the exact position that you want.
Old Sep 12, 2008 | 06:36 PM
NumberDummy
Originally Posted by xlt4wd90
Parts for [Mustangs] are really hard to come by This item isn't.
D1ZZ18518A .. Heater Temp & Defroster Control Cable / Fits: 1969/73 Mustang / Still available from Ford.
MSRP: $49.82 / FTEparts.com price: $35.87
Old Sep 12, 2008 | 07:00 PM
xlt4wd90's Avatar
xlt4wd90
Thanks Bill for the part reference.
I guess my local Ford parts guy was being lazy. He had been before on other parts, and I had to go back a couple times to talk to someone else to get what I was looking for. The other problem is, they closed their doors early this month, as in completely gone. The dealership must have been there for 40 years under different names. Robert Loud/Paradise/Pasadena Ford is no more.
I did think about scrounging the same part from similar cars, such as a Maverick, Comet, or maybe even a Granada. But the real problem was that they are all plastic, and will eventually break just like the original. For some reason, the heater/defrost diverter door on my Mustang is really stiff, even after spraying the gaskets and mating parts with silicon. I just know that a stock plastic replacement cable won't last. This project is a resto-mod, not a factory restoration, so it does not have to have exact replacements.
Old Sep 12, 2008 | 07:31 PM
NumberDummy
I guess my local Ford parts guy was being lazy. LOL, so what else is new? He had been before on other parts, and I had to go back a couple times to talk to someone else to get what I was looking for. The other problem is, they closed their doors early this month, as in completely gone.
The dealership must have been there in that same exact location for 40 75 years under different names. Fortner Motor Co/Fortner & Loud/Robert Loud/Paradise/Pasadena Ford is no more.
Bob Levine, the parts manager at Pasadena is an old friend, he was my back parts counter driver at Beverly Hills Ford in 1969/71.
When I heard they were closing, I called Bob, and got ALL the paper bound parts catalogs (over 60), all the microfiche slides, a Ford microfiche viewer, and a bunch of other stuff. = free.
The front counterman (John) is now at Puente Hills, the back counter man (Joe) is at Wondries. Bob is going into real estate, what his wife does.
New Century in San Gabriel is closing this month.
If you need something, P/M me, I'm actually in Hacienda Heights, and have methods of searching every Ford and obsolete parts dealer in the US & Canada for parts.
