Tight around the thoat
Old Sep 11, 2008 | 10:49 AM
Brian Mitchell's Avatar
Brian Mitchell
When I have the fan ON and stop at a red lite I'll get a strong smell of exhaust fumes coming out of the vents. When the truck is moving no fumes. This began after new spark plugs are put in. ( 1999 2.5 4 xlt ) You guys are the best
Old Sep 16, 2008 | 12:01 AM
35l911's Avatar
35l911
you might be breathing some one elses exaust i get that to when i run the heat in the winter time
if not you have a leak some where
Old Sep 16, 2008 | 11:44 AM
lurchy98's Avatar
lurchy98
If you removed the upper intake when you replaced the plugs, be sure you put the PCV valve back in. The last time I changed the plugs on my 2.5 I forgot to do this and had a bad exhaust smell in the cab.
Old Sep 16, 2008 | 02:49 PM
Pablo-UA's Avatar
Pablo-UA
may be it is a good idea to retorq stark plugs/....
