Help with humming noise when accelerating
Old Sep 11, 2008 | 06:33 AM
zzzz944's Avatar
zzzz944
When accelerating or when letting off of the accelerator there is a medium tone humming noise appearing to be coming from under the dash around the brake pedal area. Does not do it when running at a constant speed. Anyone have any ideas.
Thanks.
Old Sep 11, 2008 | 11:05 AM
Jarvis250's Avatar
Jarvis250
I too have a humming noise on my 07 6.0L, but I believe mine is coming from the turbo. It is a humming/ whinning noise, it has done it since new so I am not too worried about it.
Old Sep 11, 2008 | 11:26 AM
KRDiesel's Avatar
KRDiesel
It looks like you have a 1999 truck, If so then you have a 7.3 diesel not a 6.0.
on both motors I would check the drivers exhaust manfold for leaks, And if it is a 6.0 also check the flex joint at the y pipe for leaks.
If you do have a 99 I would reask this question in the 7.3 forum, that may have more ideas.
Old Sep 11, 2008 | 11:28 AM
KRDiesel's Avatar
KRDiesel
Humming is not normal, Whistle like a jet engine is normal. being a 07 I would take it back to the dealer and have them check it out.
Old Sep 11, 2008 | 01:59 PM
zzzz944's Avatar
zzzz944
I have a 2004 6.0 and it is not a turbo noise or a exhaust leak noise. I'm not sure what it is. I does not do it all the time.
Old Sep 11, 2008 | 02:46 PM
KRDiesel's Avatar
KRDiesel
Can it humm a tune?
there is a heat sheld around the turbo, I wonder if it could be vibrating.
Or there are a few relays under the dash that could be chattering.
Can you record the sound?
Old Sep 11, 2008 | 05:19 PM
dcaddi2's Avatar
dcaddi2
Thanks.
Well, I'm not sure I'm going to give you the right advice, but it won't hurt to check it.
A long while ago, my truck did a humming noise just like yours. It did drive me crazy, and it took me 2 days to find a source. My down-pipe was touching the cab, and without any vibration just made that horrible humming. I have a 4" turboback exh., so if you have factory-one, I'm not sure this could occur.
Old Sep 12, 2008 | 06:44 AM
zzzz944's Avatar
zzzz944
It does'nt sound like a vibration noise. Wonder if the brake booster could make some sort of noise or something from one of the AC dampers.
Old Dec 21, 2008 | 03:40 PM
dzdiggin'dude's Avatar
dzdiggin'dude
zzzz944 if you solved problem what was wrong?
Old Jan 1, 2009 | 03:14 PM
fishleigh's Avatar
fishleigh
i have a humming too mine is coming from d.side fuel filter area under truck 07 f 350
Old Jan 1, 2009 | 04:36 PM
dzdiggin'dude
Truck is in shop for head gaskets. It could have been coming from Degas bottle. Are you losing coolant? Mine was.
Old Nov 21, 2020 | 09:44 AM
Steven Louviere's Avatar
Steven Louviere
REVERBERATION
i too fell victim to the vibrating howl of the heat shield shimmy and aftermarket y pipe up against the firewall!
Old Nov 21, 2020 | 10:19 AM
F350 1990's Avatar
F350 1990
Those bellows (among other things) fail over time --- cab off indicated and is the preferred way in......................you can replace with multi-piece assemblies but get ready to get your contortionist permit in the process.
cyndela
Oct 2, 2014 06:09 PM
651_F350_KR
Feb 8, 2014 11:05 PM
Mr. SevenThree
Dec 21, 2011 12:15 AM
Joe Finn
1997 - 2003 F150
Dec 12, 2006 06:48 PM
maddog.pm
1997 - 2003 F150
Oct 7, 2006 04:22 PM
