hzuni
Old Sep 10, 2008 | 10:32 PM
hzuni's Avatar
hzuni
Question Need some help
Need some help. I have a 03 F350 6.0 113,000 miles with no previous problems until after driving for a short time, I stopped at store, went to start and it wouldn't start, just crank. I finally got it started. Ran good for a couple of days then again while driving down the road it quit running and has started since. I thought it was the CPS so I replaced it and still no go.
Any suggestions????
Old Sep 11, 2008 | 05:03 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
Hi there, I moved and merged all your posts...also got you where you need to be, BTW welcome from NM....enjoy FTE
You will get the help you need here.
Old Sep 11, 2008 | 05:37 AM
npccpartsman's Avatar
npccpartsman
Without knowing anything else about your truck, I'm willing to bet a cold malt beverage that it's something in your high pressure oil system OR a wiring harness issue.
Old Sep 11, 2008 | 05:27 PM
dcaddi2's Avatar
dcaddi2
I quote the HPO system also. I been in your shoes, replaced ICP sensor, IPR valve, and a new HPO pump solved my problem.
Try the ICP and the updated connector first.
Or even better, check for DTC-s.
Old Sep 12, 2008 | 11:21 PM
hzuni's Avatar
hzuni
Just some more history, like I said no previous problems tow a 35' 5th wheel. I know I was running low on fuel the first time this happened. The first time it did this I removed the cap from the secondary fuel filter to make sure I had fuel and second to see if the fuel pump was working, since I was low on fuel and if memory serves me correctly I did the same the second time it wouldn't start. after I did this it still didn't start immediately it took about 3 or 4 more trys. When it finally quit I tried everything and no go. I probably committed the mortal sin of a shot of starting fluid and did get a reaction.
And thanks for the welcome and getting me to the right place...
