Sponsored by: Real Truck
Lifting a Dually
Old Sep 10, 2008 | 02:36 PM
honda400ex's Avatar
honda400ex
Lifting a Dually
i have a 2000 F350, in about a month ill be putting a 6" lift on it. The problem im having is finding tires. Im deployed in Iraq right now so all my research has been online. im looking for around a 35 or 36", and using the stock size rims. using wheel spacers has crossed my mind, but i do still plan on towing with it( around 8000lbs ) Ive even thought of getting a " Big Rig" kit, but the only quote i was able to get was a little past the limits of my wallet. so, can anyone give me a good place to start? Thank you for your time!
Old Sep 10, 2008 | 05:40 PM
i eat hybrids's Avatar
i eat hybrids
I dont know about lifts for duallys but i have heard that fabtech makes good lifts and i have one and i tow 7k and its still tows well with very little sag. BTW i wouldnt use wheel spacers as they are bad for your front end.
Old Sep 10, 2008 | 07:49 PM
IraTodd's Avatar
IraTodd
Good morning bother from H-3 Q West!
I’ve got an 07 dually that I’ve got a Rancho lifted 4”. Here’s what I’ve found so far in my research. There are two types of wheels spacers on the market, one is aluminum that I see on e-bay for 200 bucks or so and the other is billet steel from
Off road parts store, wheels, tires, steering, suspension, winches more - Off Road Unlimited
They are made for the rear wheels to get enuff space between them to keep them from rubbing together. As far as I know ya don’t need anything for the front end, except maybe cutouts from someone like Bushwacker - Fender Results
All that depends on how large of a tire you plan on running. Most tires are either 12.50 or 70 metric width, but Super Swamper makes a 10.50 width in their SSR Radial. That I’ve seen on other dually’s on the forum an they are E rated to boot!
Here’s a link to a truck shop in South Texas that has built a bunch of trucks. Truck Toyz Performance .. Experience Matters! It has a gallery that you can choose different parameters such as truck make, year, lift height and tire size, an it will let ya look thru those trucks, that’ll give ya something to look and think over as you choose your goodies.
I’m still using the factory tires at the moment due to the fact that I want to be there(HOME) in the land of breastNbeer when I put 35 X12.50/17’s on it, an it’s kinda hard to do so from over here isn’t it
Lots of dually links on this page
Custom Dually Truck Accessories and Custom Dually Wheels
Almost every aftermarket dually rim I’ve found is on this page
Custom Wheels - Car and Truck Rims, Chrome Wheelz, Spinners, Tires, Powder Coating
Thanks for putting up with the tons of bull***** you have to put up with daily an lots of luck an be sure to post pics when your done.
Todd
Convoy Support Center
1/8th Cav 86-89
Old Sep 10, 2008 | 08:34 PM
DCSpecial's Avatar
DCSpecial
You need wheel spacers between the rear duals for anything over a 255mm width to prevent rubbing under load.
Also, be sure to specify that you have a dually when you order the suspension and you need larger rear u-bolts due to the diameter of the Dana 80 rear axle on the DRW trucks.
Here's some pics:
6" Icon with 35" Toyos:
TruckToyz Performance Image Viewer
The big wheels do look sexy...but you are right that they are pricey:
35" Nittos:
35" MTZs on Rockstars:
35" MTZ:
35" Nittos on Weld Velocity wheels:
Old Sep 11, 2008 | 08:43 AM
honda400ex's Avatar
honda400ex
Gentlemen,
Thank you for your input. I looked at most of the links and found just what i need. However, i have one final question. If i were to use a 35 x 12.5 tire on a 16 x 6 rim, will encounter any problems with the tires ballooning out? Thanx again
Old Sep 11, 2008 | 01:24 PM
DCSpecial's Avatar
DCSpecial
As you can see from the pics they do buldge out somewhat on the skinny stock wheels.
Old Sep 11, 2008 | 02:32 PM
ffadragon's Avatar
ffadragon
Honda, You will need at least a 8 in. rim, I would think. I think I would want a 10 in. rims. I know that if you are going to do much towing that you definately don't want you tires balooning.
Old Sep 11, 2008 | 09:52 PM
chiefn10's Avatar
chiefn10
honda, i have a 99 lifted dually with a fabtech lift and 35's on it. you do need the spacer for the real wheels and get at least 8" rims. i actually have eagle 589 rims instead of the stock ones. you will have to do some research to find a company that has aftermarket dually wheels. keep you head down over in the sand--i will be over there in 5 months on my ship.
Old Sep 12, 2008 | 03:25 AM
honda400ex's Avatar
honda400ex
Chief, so i was thinking about a 2" spacer fr the rear would work? and ive looked high and low for some rims, the best i can find is a 17x6.5, any ideas? thank you for your support
268Fords
Sep 16, 2016 07:21 AM
Kevinr92
17
May 13, 2016 07:58 PM
Kevinr92
Apr 27, 2016 06:47 AM
steve33444
30
Dec 16, 2014 10:06 PM
dev_jhnsn
May 1, 2010 10:23 PM
