gas mileage myth
#31
I think you'd find it impossible to control the wind's speed & direction.
IMO, barring an odd technical problem w/avator's truck that wastes fuel at the lower speed, it is "black and white" that these aerodynamically challenged pickups consume more gas at 75 than 62. It takes more work to go faster & that takes more fuel. There's no free lunch.
#32
Its not just about the wind speed and direction of the wind, elevation could play a factor. Thats where the variables start...
Like I said before, a test like this needs to be done one way, then the opposite way for it to be somewhat accurate, and should be done many times over and over to be able to claim it as debunking a myth.
I didnt mean to imply in post 29 that by just going the opposite direction would be totally accurate, I meant to say it as it would be a little more accurate!
Club, your right, the wind resistance has a huge effect on any vehicle with power, speed, and mileage.
On edit: yeah Yo george has got it right, I didnt read your reply before I wrote this one
#33
Another point to be made about hp/torque ratios is my truck burned more fuel as torque went and hp went down (yes, my scangauge read that as well) and the opposite when torque went down. Torque in general measures the amount of work done by an engine, as it works less it requires less fuel. I found myself glued to the scangauge display as my truck encountered hills both up and down and wind resistance pending how strong. It will aslo calculate what mpg's were done the day before and total mpg's for the whole take and not just live data. Unless you have one of these units you are always going to be off in your calculations to some degree.....I highly recommend the scangauge as it is the best addition I have done to my truck so far.
#34
#35
Since your reading comprehension is bad, I will explain it further to you. I said MY truck. Not yours. Not Bobs. Not your boyfriends. MINE. It's been said a million times. Every vehicle is different.
Now, If I go back to stock 255 or even 245 series tires, then I could probably use OD more often and increase my MPG readings.
#36
#37
when i say black and white i mean its not that simple and there is more affecting it than the obvious reasons....
Every truck is different and respond differently to load(wind, hills, throttle) ... you take 10 trucks identically made by ford and do the same tests, i bet they all result in the same MPG( give or take .5) ... there are so many different combination of our trucks its damn near impossible to generalize em... there just different...
I love my truck... And i will NEVER sell it... it will ROT in my garage before i see it sold to scrap... i will either enjoy driving it.. or enjoy looking at it ( heaven forbid fuel goes above $15/gal)
#38
Speaking of bad "reading comprehension" guess you missed "IMO, barring an odd technical problem w/avator's truck that wastes fuel at the lower speed, it is "black and white" that these aerodynamically challenged pickups consume more gas at 75 than 62." That exemption obviously goes for other individual vehicles. Of course odd exceptions don't "debunk" the alleged "gas mileage myth". "MY truck" is stock, as FORD engineers designed it, making it perfectly representative of millions of other F150's just like it. Its 'YOUR truck' that is markedly "different" leaving your input somewhat irrelevant to this discussion.
The topic was avator's MPG comparisons, which implied everything remained the same except speed, w/specific range. This presumes high gear at different speeds. No need to derail into modified pickups that can only rarely be driven in OD, struggle to get 8-10 MPG, or differences between gears "@ 60 mph" only.
Contrary to your "black and white" claim, "Every vehicle is" in fact the same in atleast 1 regard-ALL are subject to increasing air drag w/increasing speed. Outside of very specific anomolies, the generally accepted FACT that MPG declines w/increased cruising speed (certainly in the 62-75 MPH range) remains true for virtually "Every vehicle". Vehicles w/faults or mods that compromise design certainly can exhibit an endless variety of problems in any speed range.
#39
Well,
All I can tell you guys is that my truck doesn't get good gas mileage at all.
This last July it got only 8.5 miles per gallon pulling a 4500lb camper...totally expected.
I'm not complaining and I sure can't pull the camper with my Escape.
I might get 12mpg not pulling anything.. So everyone in here getting 17mpg with a 5.4 if any...hats off to you!
#41
i never said anything about increasing speed and increasing resistance.... that is completely true... all im saying is that there are tons of factors to consider and some of them are not always obvious... relax man, you take things to personal
#42
avator's "gas mileage myth" premise clearly attempted to rest on just the single factor, change in speed from 62-75, which is perfectly fair. Unfortunately "tons of other factors" where not "considered" when he concluded he'd "debunked" it.
While it is possible to drive essentially in the wrong gears at the wrong speeds & purposely skew intended design parameters, resulting in impractical MPG anomalies-these exceptions don't alter the general facts of normal driving. Of course they don't apply to avator's original premise either, which presumes normal cruising speeds in high gear & the same mix of shifting.
More importantly, anyone driving w/the intention of maximizing MPG would not go there.
Nothing "personal" or mythical about it. Purely physics & common sense.
#44
http://www.vettenet.org/torquehp.html
I also know for fact that at 0 RPM, HP and torque are equal for ANY internal combustion motor.
