Starter problems
Old Sep 10, 2008 | 09:32 AM
wfearrington's Avatar
wfearrington
Starter problems
Turn of the key ... nothing ... no noise whatsoever. Jumped the solenoid and starter spins but does not engage. Getting 12V to the battery cable at the solenoid but I have not confirmed if power is getting to the small terminal on the solenoid. While jumping the solenoid, why would it just spin and not start?
Old Sep 10, 2008 | 09:46 AM
ranger88a's Avatar
ranger88a
Did you jump the relay on the starter? If you did and it turned, do check for power at the small terminal while cranking. Also, the starter gear sounds like it's not engaging which would be a starter problem. Hopefully a starter will fix both problems.
Old Sep 10, 2008 | 09:58 AM
wfearrington
I did not jump the relay. How do i do this? I did put a multimeter on the small terminal (pos. on terminal, black on frame) and got no reading. Would this mean it is the solenoid or are you still thinking "starter"?
Old Sep 10, 2008 | 11:36 AM
Parts Guy Wyatt's Avatar
Parts Guy Wyatt
Former Vendor
Did you have the key in the "on" position when you jumped the solenoid? Dan.
Old Sep 10, 2008 | 12:04 PM
wfearrington
yes, I had the key on and when i jumped the solenoid, the starter just spun
Old Sep 10, 2008 | 12:05 PM
wfearrington
Would it be possible for the key not turn the starter because of a safety feature that recognises that something is wrong with the starter and prevents the key from working?
Old Sep 10, 2008 | 12:06 PM
wfearrington
Or do i have another problem besides the starter?
Old Sep 10, 2008 | 03:24 PM
Slvr 2008 SS SC's Avatar
Slvr 2008 SS SC
I had a remote car starter installed on my 08. If the engine is running and I turn the key it will not try to start. Is this standard on the Fords or is this a feature of my car starter? Could this relate to your problem with your starter? Just wondering.
Old Sep 11, 2008 | 08:41 AM
ranger88a's Avatar
ranger88a
No power to solenoid is an issue, is your truck new style or heritage? If new style, starter solenoid is in the fuse box Lh. side 3rd up from bottom just swap a relay and see if it works. If heritage, you have a solenoid on the firewall that looks like an old starter relay jump the two big terminals. Hope this helps.
Old Sep 12, 2008 | 08:38 AM
wfearrington
ok .... this is getting aggrevating! I took the starter off and had it checked out and they said everything was fine with the starter, it fired and would engaged like it was supposed too. I put the starter back on, replaced a fusable link for the ignition and still doesn't work. I wanted to replace the ignition relay but they didn't have one in stock. I will be replacing that today. However, what is strange to me is that when i jump the solenoid, it sparks and the starter just spins freely. If the starter is ok, wouldn't it crank? By by-passing the solenoid, aren't I by-passing all of the electrical components that could prevent it from starting, like the ignition, solenoid, etc..? I just don't get it.
Old Oct 6, 2008 | 08:46 PM
gelato583's Avatar
gelato583
engine turnover after 5 seconds on start
sorry i cant help but i have a problem with my starter also.. every few weeks i turn the key and it tries to start but wont turn the engine over for about 5 seconds sometimes... anybody got and help for me out there???
Old Oct 6, 2008 | 09:01 PM
bridge's Avatar
bridge
Sick 'n Tired
Which engine do you have?
Old Oct 6, 2008 | 09:12 PM
gelato583's Avatar
gelato583
i have the 5.4 in an 06 crew
Old Oct 6, 2008 | 09:21 PM
bridge's Avatar
bridge
Sick 'n Tired
I've heard of a similar recurring problem on the 4.6L engines that had to do with the IAC; not on the 5.4L though. On the 4.6 the problem only occurred when the engine was warm...like when you go to a gas stations, kill the engine, fill up, then restarting would take several seconds of crank time.
Old Oct 7, 2008 | 12:43 PM
gelato583's Avatar
gelato583
that is exactly what is happening to me it gives me a problem when it is warm.. what does IAC stand for and how do i fix it or what did your friend do?
