Turning off daytime running lights
Old Sep 10, 2008 | 09:15 AM
urcysk's Avatar
urcysk
Any one know how to turn off day time running lights. I have a F250 1991 4X4 Automatic, I know some models you can just press the E-brake pedal a little but that dos'nt work on this one, any help would be appreciated
Old Sep 10, 2008 | 09:38 AM
quicklook2's Avatar
quicklook2
the module is inside the engine compartment on the front side of radiator support next to the radiator on the drivers side.
it is the larger of the two things there. (part number 15A272)
unplug it and see if that does it.
Old Sep 10, 2008 | 11:40 AM
quicklook2's Avatar
quicklook2
i went out to look at my f150 and it is between the grille and the front of the radiator support.
on trucks without dsl, like mine, it is just a plugged end of a harness.
Old Sep 10, 2008 | 02:02 PM
urcysk's Avatar
urcysk
thank u it worked
Old Sep 10, 2008 | 02:19 PM
quicklook2's Avatar
quicklook2
i would put some tape over the connector so i does not get water in it.
mine has a plug over the connectors.
glad it worked.
