Gee, I have been towing every thing with by step bumpers, with a two axle trailer stack high with hay to 3,640 pound load I just hauled to Metals Recycling last week. I as towed home on a dolly a 95 F150 ex cab using my step bumper. I have been towing with my step bumpers on every truck I have owned for the last 38 years.
Not sure what you all are talking about, that is what they put them on for isn’t it.
You'll be fine towing it on the step bumper. People do it all the time. Far more important to safety is how your speed and how you anticipate stopping.
I agree with being really careful about towing with the step bumper. The bumper may look good on the shiny side, but a close inspection may show that the strong parts underneath are all turning into rust, especially on an 88.
You should know the safe limits of that truck. On the drivers door post is the GVW for your truck. The following should be factored in before you tow.
Base Curb Weight + Cargo Weight + Passenger Weight + Tongue Load or King Pin Weight = Gross Vehicle Weight (GVW)
If the total weight added up exceeds this then you are not safe.
It adds up quick.
The sticker on the door says gross weight for vehicle is 6250 lbs. The sticker on the bumper is a Hercules rated at 3000 lbs. tongue weight and maximum 15000 lbs towing.
the 6+stick has to be rated near 2000-2500 tow rating assuing a decent rear axle.
the weak part? clutch, then the tranny itself in that order.
It depends on the diff gear. My 1990 F150 4.9 with 5 spped & 3.55 diff gears w/tow package was rated to tow up to 6,000 pounds. I regularly towed my 65 mustang on a tandom axle trailer with brakes with no problem- total weight for car & trailer (steel) was 5,000 pounds. Very stable at city & hwy speeds. I prefer the trailer on hwy as other drivers don't always see you towing a vehicle behind, change lanes quickly and can hit the vehicle...with the trailer, if they do make contact it's basically sol for them as the car is somewhat protected.
you might wanna chack that. the tow rating is in the owners manual in a chart in the rear. read the correct table, the manual ratings are about half that of the auto. In 1990 a F150 4.9 3.55 auto was around 6000
I think the petitioner had a 308 - hence my answer of 2000-2500
as for step bumpers - I have never seen a trailer that has its frame level when attatched to a step bumper. just dont do it, if you saw how these were mounted to the frame you would never hook up. (plus you cannot make a tight turn on an aframe tongued trailer)
Ford sold and installed receivers for a reason. the v5 rating on the bumper has NOTHING TO DO WITH WHAT IT CAN TOW WHEN INSTALLED. It has something to do with when the bumper will deform between the mount points and the ball mount. IIRC correctly the ford guild to towing does not recommend using the bumper (in fact, in the years we are posting about, the bumper is not even included on the truck OR tow package, it was an option as many class 4 hitches interfere)
Just because the bumper says that it is rated for 15000 lbs of towing does not mean that the truck is necessarily capable. According to your door sticker (The legal GVW for that vehicle) that weight should be the only one considered and should not be exceeded. It is ultimately up to you. Be safe
Dan.
Dan.
I always thought the GVW was the total weight that a vehicle could carry minus of course it's weight? Does it also pertain to what it can pull?
If you could post a pic of your "step bumper" we'll check it out....it MAY be one of those aftermarket "cowboy style" bumpers that were popular about 20 years ago...and be OK to put a ball on and tow with, BUT if its just a plain stock type step bumper DON'T TOW WITH IT even if someone else has!!
i used to tow with a stock bumper never had any problems...my I6 is rated to pull 2600ibs i beleive with 3.08s and m5od,but ive pulled close to 8k pounds of hay+ the trailer...the truck has no problem moving it the problem i had was swerving going around 45 mph where an f250 would be much better suited for that
