Trailer wiring problem
Old Sep 8, 2008 | 05:36 PM
Homer F-18's Avatar
Homer F-18
2003 F250 7.3L PSD crew cab. I pull a boat trailer using the 4 pin connection to the trailer. When I hook up the lights, only the trailer side lights and bright (brake) tail lights work; no parking lights and no turn signals on the trailer. This is only when the parking lights are on in the truck. If truck lights are off, the trailer has NO brake lights or turn signal lights. In other words, the truck parking lights make the trailer brake lights come on.
The truck lighting system works perfectly. I thought I had a short in the trailer wiring but when I checked the 4 pin plug on the truck, the tester shows the same thing - no turn signals only brake lights with the parking lights turned on.
SO... it seems my truck has some wiring problem between the truck lights and the 4 pin plug. I'm at a loss on what to do next or how to fix.
HELP! Please.
I've owned the truck since new. No modifications from the factory. It's worked perfectly until now.
Thanks,
Homer
Old Sep 8, 2008 | 08:57 PM
ReAX's Avatar
ReAX
So key on, parking lights off.
No turn signal, no brake, no parking lights.
Key on, parking lights on
No Turn signal, no brake, yes parking lights
or
All lamps are on?
First thing I would check is the continuity of the white wire to ground. The white wire provides a ground, you can also ground a trailer through the hitch if it's clean enough and the trailer is wired so.
Then the Green wire should have 12v when the brake is pressed. It should also pulse if the turn signal is on. I think this wire runs the pass side.
The yellow wire should have 12v when the brake is pressed. It should also pulse if the turn signal is on. I think this wire runs the drivers side.
The brown wire should only have 12v when the parking lights are on.
Use a good chassis ground to test these and not the one in the harness. It's possible you have a grounding issue.
Old Sep 8, 2008 | 11:03 PM
Franklin2's Avatar
Franklin2
If this plug is factory, you should have trailer tow fuses up front for this circuit. I agree also, check the grounding of the white wire to the truck.
Old Oct 4, 2008 | 06:30 PM
shorebird's Avatar
shorebird
No short in the trailer but maybe improperly wired? Trailer Wiring Harnesses Troubleshooting - etrailer.com
http://www.etrailer.com/faq_wiring.aspx
Culvert
Nov 10, 2016 09:31 AM
SEAL1
Jul 13, 2015 05:30 PM
Justin03PSD
17
Jul 11, 2014 06:00 PM
JayzDaddy
26
Jun 3, 2013 11:38 PM
mitsudave
1997 - 2003 F150
13
Oct 24, 2012 06:27 PM
