I found that the hose coming from the pcv valve the the air intake tube was capped off then put into the air intake tube. Should I leave it capped or uncap it.
Well, I'm confused
But that is not uncommon for me.
I want to look at my Haynes manual and get a better about what you describe.
I got the impression you were describing something that a previous owner had done.
hi, i have taken the pipe from the pcv valve and fitted a k&n small filter to let it breathe.
the other end i then capped off. this caused no problems with running and did not flag-up any codes. this had to be done due to it caused problems with the propane conversion. but i would follow the advice and refit as per stock. good luck bokker.
