292 soild lifter breakage problem
Old Sep 7, 2008 | 05:39 PM
mahony63's Avatar
mahony63
I have a 292 thats bored .40 over new internals rebuilt heads, the whole motor is solid. i have maybe 100 miles on it im on my second isky cam and on top of that i have replace all of the soild lifters twice i get like 50 miles and then they break. I have evan tried a different set of heads on it.
im not beating on it either. I put a small block and a aod in it because that only took a weekend!!!!
but i wanna keep this engine b/c i have too much money in it.
So any ideas? maybe some kind of new springs ?
Old Sep 8, 2008 | 12:08 PM
garbz2's Avatar
garbz2
Isky should be solving this problem. Not us....
Sounds like plugged oil gallery and failure of the mushroom tappets. ot the block was shaved and the pushrods are too long.
Garbz
Old Sep 8, 2008 | 12:12 PM
mahony63's Avatar
mahony63
<P>oil gallarys are fine and i used a adjustible pushrod to make sure it was ok.</P>
<P>&nbsp;</P>
<P>&nbsp;</P>
Old Sep 8, 2008 | 12:25 PM
garbz2's Avatar
garbz2
Isky may have some quality control issues then with either the mushroom tappets ot the stick, What is thier take?
Garbz
Old Sep 8, 2008 | 12:33 PM
mahony63's Avatar
mahony63
that i can buy another one from them if i want.
and they hope the tired one is a charm
Old Sep 8, 2008 | 02:12 PM
Redmanbob's Avatar
Redmanbob
Broken lifters? What exactly is happening to the lifter ? worn out tappet, or ? I would expect the push rod to bend before a lifter breaks. Are the lifters spinning/sliding freely in the bores upon assembly ? This being a flat tappet cam, are you using any zinc additive during break in/use ?
