CEL Light on!
Old Sep 7, 2008 | 12:00 PM
-=Pit=-'s Avatar
-=Pit=-
CEL Light on!
Just my friggin luck I get a CEL light at 39965 on my 06. I did notice something strange and wonder if this triggered it. I filled my tank up that morning drove to a store. As we were leaving and were at the on ramp to the 60E in CA I noticed my DIC stating fuel low and the gauge was below E. I knew this was bs because I just placed 26 gallons in it. I pulled over shut the truck off and then restarted it. The gauge was reading normal at that point. Got half way home and bang it was reading below E and Low Fuel. Pulled over shut it off and restarted it. It's been fine since but now I got a CEL light. Performance is the same at this point, could the issue above withe guage/sending unit trigger a code for a CEL to come on?
Pit
I wasn't going to buy an extended warranty but now I think I am.
Old Sep 7, 2008 | 03:48 PM
BPofMD's Avatar
BPofMD
Veteran: Navy
Sure would be a lot less expensive to have purchased the extended PRIOR to reaching 36,000 miles/3years!!!
Old Sep 7, 2008 | 05:10 PM
BowTieHatr's Avatar
BowTieHatr
i see you have a 06. ill bet your light is on with p0460 code. seen several of these issues and there is a reprogram out for this code. it repairs false fuel level input to the pcm due to irratic readings from the sending unit.
Old Sep 9, 2008 | 12:30 AM
-=Pit=-'s Avatar
-=Pit=-
Update- They are replacing the fuel tank sending unit. Goodwill at this point!
Pit
Old Sep 9, 2008 | 09:44 PM
-=Pit=-'s Avatar
-=Pit=-
Ok Latest Update...
Bowtie chime in or someone else if you understand all of this.
Sending Unit was replaced in the fuel tank.
Codes P0460, P0463
PCM Reprogramming
OPCODE: 12650D45
OPCODE: 12650D82
OPCODE: 12650D45
Time will tell.
Pit
Old Sep 10, 2008 | 06:46 AM
BowTieHatr's Avatar
BowTieHatr
you are good to go
