Sponsored by: Real Truck
Please help! Ford alarm installation
Old Sep 6, 2008 | 03:43 PM
SneakyF350's Avatar
SneakyF350
Unhappy Please help! Ford alarm installation
2008 Ford F-350: Crew Cab, Lariat, 4X4, 6.4L, short box
I'm trying to install a Ford alarm upgrade. Going by the instructions. I cannot find the color of wires they want me to use at the designated locations in the truck. This is a Ford alarm!
Are their any wiring diagrams available that may be up to date?
Does anyone know what color the dome light wire and door lock positive wires are?
Old Sep 6, 2008 | 07:15 PM
ReAX's Avatar
ReAX
PASSIVE ANTI-THEFT YES TRANSPONDER SEE NOTES
This vehicle is equipped with an IMMOBILIZER passive anti-theft system. Please refer to the security diagram before any remote start installation.
12 VOLTS Blue/red Ignition switch harness +
IGNITION White/orange Ignition switch harness +
ACCESSORY Violet/Green Ignition switch harness +
ACCESSORY 2 Brown/yellow Ignition switch harness +
STARTER Blue/white Ignition switch harness +
KEY SENSE Blue/gray Ignition switch harness +
TACH SIGNAL Blue In driver's kickpanel (loose wire) AC
May also be found in harness left of steering column.
LOCK Blue/green In driver's kickpanel -
UNLOCK Yellow/purple In driver's kickpanel -
DOORPIN Blue In harness from under driver seat +
BRAKESWITCH Violet/white At brake switch +
May also be Yellow/green in driver's kickpanel.
PARKLIGHTS Violet/white In driver's kickpanel +
HAND BRAKE White/violet In driver's kickpanel -
HORN Yellow/red Steering column -
CLUTCH SWITCH Blue/orange In driver's kickpanel
Try the door pin for dome light. Installers seem to like to cheat, since the door lamp will come on when any door is opened, it is easier to use it instead of all of the diode isolating.
Lock should be Blu/grn and is a ground. Put your meter on this wire, you should have something near 12v on that wire. When you press the lock button it ground out leaving you with less than 1v.
Old Sep 6, 2008 | 09:56 PM
SneakyF350's Avatar
SneakyF350
Thanks, will give it a try.
Old Sep 9, 2008 | 05:23 PM
SneakyF350's Avatar
SneakyF350
Question
Alarm installed but truck will not start with alarm module plugged in. I jumped across the terminals in the alarm wire harness, connecting the in and out for the starter kill and it starts. I was told that the starter kill feature can conflict with the PATS key. Is this true?
Old Sep 9, 2008 | 08:39 PM
ReAX's Avatar
ReAX
Not really. The pats is separate from the starter kill. Start kill interrupts the wire that runs from the key to the starter solenoid. My ford RS didn't use a relay and handled the start kill inside the brain. When the module didn't have const 12v, I couldn't start the engine. Just so this doesn't pull massive amounts of power, I believe it was hooked into the ign1 wire. When ign1 is energized, the starter kill was deactivated.
When you have an out board relay, it's done a little differently. I can help out more with those.
Old Sep 10, 2008 | 04:59 AM
79BRNC's Avatar
79BRNC
Go to this site ------->> http://www.fordaccessoriesstore.com/fas/b2c/home.asp
pick;
Tech Specs
installation instructions (Genuine Ford Accessories)
electronics
remote start /vehicle security systems -truc
Old Apr 24, 2024 | 04:34 PM
JohnyChevyEG's Avatar
JohnyChevyEG
6th Gear
Sorry to bring an old thread back to life but I would like to add the factory alarm system to an 08 F350. Does anyone have these instructions handy?
afrank
1997 - 2003 F150
Mar 31, 2015 05:01 PM
OLDnSLOW
Electrical Systems/Wiring
Feb 26, 2011 05:04 AM
kwimer4594
Feb 7, 2009 05:51 PM
ag-ford-4x4
May 4, 2006 06:55 PM
