Offroad & 4x4
Difference between 2 lifts. Any Compents?
Old Dec 23, 2002 | 06:16 PM
first time 4x4's Avatar
first time 4x4
Old Dec 25, 2002 | 08:44 PM
300Runner's Avatar
300Runner
I need some help. I'm trying to decided between a 2 inch skyjacker susp. lift or a 2.5 inch Rough Country lift. I want to fit a 32 or 33 inch tire and still have a little room to flex the tire in case something happens. Someone I know put on a 2 inch lift and he says he can fit 33;s but he hasen't tried yet and he dosen't seem to have that much room. Any input is helpful imput. Thanks.
Old Dec 25, 2002 | 09:18 PM
pbrstreetg's Avatar
pbrstreetg
I know if you have a 80-96 you will have no problem with 33's.
Old Dec 25, 2002 | 09:49 PM
MustangGT221's Avatar
MustangGT221
You can't fit 33's on a stock 4wd 80-96 unless you like to rub things. They look ugly and are way to crammed. My 32's rub on the radius arm pretty bad and they are 11.5" wide not 12.5" wide. However, get the skyjacker coils, 1.5-2" lift is enough but a 3-4" lift would be ideal for 33's. Rough country stinks. You'll probably want to regear if you get 33's, they'll be sluggish even if you have 3.55s or horrible if you have 3.08s. I have 32's on my stock 4wd truck and they look good I think. I'm going to 6" and 35s but for now it looks fine.
Primary rig is Green Thunder:
95' F-150 XLT 4x4, 302, 5 spd, MSD 6A, Flowmaster Exhaust, Sunroof, Clear corners w/ Diamond headlights, CD player with 2 10" subs and some 32" BFG Muds .
Check out my Gallery for a look-see.
Justin - One Happy FTE Member
