Sponsored by: Auxito
help
Old Sep 6, 2008 | 10:40 AM
chandler1997's Avatar
chandler1997
Post help
hello
I have 97 F-150 4x4, havent had it for very long. When I turn the steering wheel, either direction, you can hear a "squeaking" sound coming from the front end. Ive crawled under and dont really see anything loose or rubbing. Just wondering if anybody had any ideas for me.
Old Sep 6, 2008 | 11:44 AM
ScottInTexas's Avatar
ScottInTexas
Give me coffee - Or beer!
Are you sure the power steering fluid is full? The power steering pump will squeal if it is low on fluid. Don't overfill it. Is there any sign of leaking around the pump or hoses?
You get better responses to your posts if you use better titles. "Help" is one of the worst titles you can use and some people here may not even look at posts titled help.
Hope that helps.
Old Sep 6, 2008 | 01:24 PM
chandler1997
steering noise
The power steering fluid is full and there is no leaks anywhere. It just makes a squeking noise whil turning. Ive also greased the front end and that didn't seem to help.
Old Sep 6, 2008 | 02:38 PM
slc10844's Avatar
slc10844
You might have a dry ball joint or tie rod end. More than likely a ball joint. Get someone you trust and put them behind the wheel. Start the engine and have them turn wheel to the point where it makes the noise. Check each joint with your hand while it produces the sound. You'll know when you found a bad one.
Old Sep 6, 2008 | 06:38 PM
chandler1997
steering noise
Alright i will give that one a try and get back with the results, thanks for the help.
Old Sep 6, 2008 | 10:58 PM
LxMan1's Avatar
LxMan1
Usually the non lubable ball joints are the culprit.
