03 7.3, please help
Old Sep 5, 2008 | 09:10 PM
Leebak's Avatar
Leebak
Angry 03 7.3, please help
Just picked up my new 03 7.3 with 54,000 miles. As soon as I paid the man I hooked up my sct and downloaded a tune of Jody's from DP tuner. It runs great as I figured it would, however now I have the check engine light staying on, the a/c compressor will not engage, and my tach stopped working. All this worked prior to this. Does anybody have any ideas? I untuned it and went back to stock, still no change. Please help, I am drving home right now and it is getting hot in here with no a/c. thanks:
Old Sep 5, 2008 | 09:22 PM
megawatt00's Avatar
megawatt00
Can you scan to see if yo have any codes?
Old Sep 5, 2008 | 09:27 PM
Leebak's Avatar
Leebak
I dont have a scanner and no where near a place that is open to scan. Do you have any ideas what is going on? Thanks for your help.
Old Sep 5, 2008 | 09:34 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
The tuner you have won't pull codes?
Old Sep 5, 2008 | 09:35 PM
Leebak's Avatar
Leebak
no sir it doesnt have that capability.
Old Sep 5, 2008 | 09:37 PM
empiretc's Avatar
empiretc
that is a real bad case of PMS right there!
tach sounds like it could be ABS sensor, but still, check you batteries and terminals. check all fuses as well.
Old Sep 5, 2008 | 09:40 PM
megawatt00's Avatar
megawatt00
I wouldn't suspect glow plugs just yet. It's not cold enough for them to come on. The WTS light is not controlled by the glow plugs. It is just a reminder light.
BTW Kris nice mod....
AIH mod, Boost fooler, Banks Ottomind, Kwik filter with AFE torque tube, Billet thermostat, Foil delete mod, Zoodad mod, Straight pipe, CCV with Catch can, Superchips stacked with Evolution, ATF in PS, Stancor GPR, TAG I & II, Speed Bleeders, Fumoto, Shimmed FPR mod, AC valve mod, Heated seat mod, TC & GPR LED mod, Dfuser 18k mod
Old Sep 5, 2008 | 09:45 PM
empiretc's Avatar
empiretc
did i miss something ???
Old Sep 5, 2008 | 09:53 PM
PowerstrokeJunkie
Its kind of a joke... Dont take it serious.
Old Sep 5, 2008 | 11:09 PM
big poppa's Avatar
big poppa
Your a friggin trip Kris, remembered that from yesterday, lol.....
Old Sep 5, 2008 | 11:35 PM
empiretc's Avatar
empiretc
you all are gonna scare the newbies off!
Old Sep 5, 2008 | 11:43 PM
big poppa's Avatar
big poppa
No, not at all David, yesterday a member here put in his sig, ATF in my PS, it was all in fun, everybody had a respectable laugh. As to the question above, check out what the guys said above and if that doesn't help, call Jody at DP.
Old Sep 5, 2008 | 11:49 PM
bkcowboss's Avatar
bkcowboss
I have some electrical issues, the clear up if I cycle the light switch....don't know if that will help
Old Sep 6, 2008 | 01:55 AM
Leebak's Avatar
Leebak
ok, I got her home, hot trip, anyway, there is no voltage going to the a/c cmpressor when the a/c is on, and the tach still doesnt work. When you turn the key on, the tach jumps over like normal, then comes back and never moves again. The ses light is still on when it is back in the stock tune. The tunes I have from jody on my SCT are for my 1999, 2000, and 2001 excursion. Would the pcm for the 03 be different enough that the tuner didnt work well with the pcm? All of this worked as it should prior to the tuner. I have disconnected the batteries and maybe it will clear the pcm and all will be good, not sure. I work on all of these 7.3's for everybody out here on ranches and what not, and have never seen this before. If anybody has any info, or ideas, I do appreciate the help. Thanks
Old Sep 6, 2008 | 05:05 AM
megawatt00's Avatar
megawatt00
That is a possibility. Jody's tunes are written for each particular PCM. There was a thread a couple of days ago where someone tried to down load a tune from a Superchips, I think, and he had to have the PCM reflashed by the dealer.
