I can normally find everything I need to know without asking but not on warning lights. So here goes. I have 2003 f 250 KR I bought it used and have never had a owners manual. The light was two rows of dots ( 5 or 6 in each row)going up and down with an arrow going from left to right throught them. It is on the upper right side of the gauge area. Do ya'll know what this indicates? Thanks in advance.
This is the air filter restriction warning light. It indicates that your air filter restriction gauge (in the engine compartment attached the the filter box) has moved to the "replace filter" side.
Check the restriction gauge and replace your air filter if necessary.
Then Select Owner Guides. Then you will enter your Year, Make, Model and you will be presented with a list of Owner's manuals, Diesel Supplements, etc.
