Computer Chips & Tuners
Edge Programmer
Old Sep 5, 2008 | 04:56 PM
bansheeduner's Avatar
bansheeduner
Edge Programmer
i just got an edge evo 2 for my 01 screw 5.4l it has a k&n intake throttle spacer and exhaust what the best way to custom tune the truck i want to stay on the towing level to keep 89 octane gas any tips or the best way to tune it would be greatly apprciated and how to maybe get the best mpg also.
Old Sep 6, 2008 | 09:56 PM
Ultramagdan's Avatar
Ultramagdan
A lot is going to depend on how heavy your foot is. If you like to dig deep into the program you will need premium.
Old Sep 8, 2008 | 08:01 AM
DAFBFD58's Avatar
DAFBFD58
I will tell you with mine in my 250 level 2, if I run 89 on the 87 program I get better MPG. Also I have the timing up a degree or two, I have dropped the max RPM for shifting. From 5300 to 5000 on first shift. That way if I'm in it it does not lag. There are a few things you can do to change your mpg, you just have to try things. Oh and try to stay a little bit behind a car or another vehicle. That helps the air flow over the truck better and makes the engine work not as hard. Well in my case since I am lifted it works for me. With my 35s and stock gears in the 250 I am stuck around 13-15. Now it has gone higher then that but it has been on the highway and I have been cruising with some truckers and got about 17-18
