Sponsored by: Real Truck
Please Help
Old Sep 5, 2008 | 12:43 AM
Powerstrokeredneck70's Avatar
Please Help
I just traded my 95 Ranger for a F350 Crew Cab with 7.3 Powerstroke. This is my first diesel. 3 days ago I had my water in fuel light came on. I was told that there is valve to drain the water out. Is this true??? If yes where is it? Hope u can help me.
Old Sep 5, 2008 | 03:05 AM
rusty350250's Avatar
rusty350250
sure is, it is a yellow lever on the back of the engine mounted fuel filter. put a catch pan under the motor and open the valve and you will here the liquid flowing out of the valve then close it after a few seconds. the engine mouted fuel filter will be under a small plastic cover in teh middle of the engine, just stand on the bumper and look down at it and around it you will see the yellow lever
Old Sep 5, 2008 | 04:32 AM
rocdril's Avatar
rocdril
Ditto, what rusty said, just make sure to use a large drain pan, not just a bucket!
Old Sep 5, 2008 | 07:14 AM
F350-6's Avatar
F350-6
Welcome to FTE. As the others have stated, just rotate the yellow lever clockwise 1/4 turn to drain the water out. Close it back up and you should be fine.
We do have a section here dedicated to the 7.3 motor located a little further down the main forum listing. Spend some time reading there, and don't be afraid to ask any questions. You'll soon know more about this motor than you ever dreamed of.
Here's a shortcut to the 7.3 section 1999 - 2003 7.3L Power Stroke Diesel - Ford Truck Enthusiasts Forums
Old Sep 5, 2008 | 07:23 AM
03_PSD's Avatar
03_PSD
Welcome to FTE, congrats on the new purchase!
Old Sep 5, 2008 | 07:03 PM
I want to thank you all for your help. I found the valve and the light is no longer on. Thanks again
Chucksayles
Oct 19, 2011 01:31 AM
nbtone
Jul 30, 2009 01:49 PM
thundertex
Oct 12, 2008 11:18 AM
truck_2
Nov 14, 2006 11:10 AM
WilliamCH
Oct 28, 2004 11:42 AM
