E4od PSI
Old Sep 4, 2008 | 03:51 PM
Blackwalls's Avatar
Blackwalls
E4od PSI
I've would like to know the psi figures for a 1994 E350 idi non-turbo
of the output ATF fluid line to the radiator. Is there a minimun psi for the
return line back to the transmission? Or is there a allowable psi drop across
the added coolers that the fluid passes through?
Thank you in advance,
Steve
Old Sep 4, 2008 | 11:49 PM
ford trans tech's Avatar
ford trans tech
there is no spec. for cooler pressure
it is a lubrication circuit and has an infinite resistance in the system
the only pressure spec is for line pressure
it should be around 65 psi at idle in drive and 180 psi at wot stall
Old Sep 4, 2008 | 11:50 PM
ford trans tech
there is a flow test however it should be 1 quart in thirty seconds
awq134
2009 - 2014 F150
Jan 24, 2011 09:26 AM
SLAMMIN 22
19
May 17, 2010 08:03 AM
rtazz17
Dec 9, 2009 07:41 PM
jetjock16
Nov 12, 2002 09:16 PM
Chapstick
Feb 10, 2002 10:00 AM
