Advice PLEASE!! 2000 F450 problems.
I have a 2000 F450, 7.3 PSD, 6 spd. manual, 152,000 miles.
I started getting the service engine soon light with a rough idle at start up untill fully warmed up, now it sometimes will wait until I start driving to pop on but with the same result. It seems to need a load on the engine after warm to clear up, like pulling a big hill.
After reading many threads I took it and had the codes read, I was told I had a code for #4 injector, the guy told me it was either the IDM, or the under valve cover harness..... Does this sound correct? It feels like an injector to me but????? If it was a wire harness why would it clear consistantly? The only reason I think it could be the computer is because sometimes I will loose throttle when at idle going into gear, no throttle and service engine light. Is this connected or a seperate issue???
PLEASE HELP!!!!!!
As far as the no throttle when going into gear, I would check your TPS (throttle position sensor) on the back of your go pedal.
You'll be looking for something like this
The #4 injector is on the driver side, so that's the valve cover you need to pull off. As long as you've got the valve cover off, be sure and re-torque the rocker arm pedestal bolts to 20 ft lbs, and the lower injector hold down bolts to 120 in lbs.
If it's just a loose clip you can make a shim to keep it from happening again. Just make sure whatever you use to shim the connector doesn't have a way of falling out. I shaved the end of a quarter down for mine.
