We went to the U pull it
Old Sep 5, 2008 | 01:09 PM
86F150302's Avatar
86F150302
Sweet. Get a picture of them seats in the truck. Im wanting to put buckets in my truck too.
Old Sep 5, 2008 | 02:57 PM
uncle.stosh's Avatar
uncle.stosh
Originally Posted by LARIAT 85
I have been looking for a complete steering column like the one you got from the junkyard for a long time now. Would you be interested in selling it? PM me.
I looked for you today and found 2-3 but they were all real sloppy.
There is another place that I'm going to try tomorrow. I'll let you know what I find.
FWIW: There is a slight difference in the column with the AOD, it has the D with the White background signifying over drive. I still don't know what's different about the column though if any.
Old Sep 5, 2008 | 03:08 PM
ri_truck_guy's Avatar
ri_truck_guy
There's no difference in the column....there are different shift connecting rods between the column and transmission depending on the engine, and the shift indicator looks different, but has the same number of shift points.
Old Sep 5, 2008 | 03:24 PM
uncle.stosh
That's what I thought, but in LARIAT 85's original post he was pretty sure that there was a difference.
Old Sep 5, 2008 | 03:43 PM
LARIAT 85's Avatar
LARIAT 85
The difference is in the wiring connector. From what I have been told, if you try to use a C6 column assembly for an AOD truck, the wiring isn't compatable and truck will not even move. Sounds crazy I know, but several sources have told me the same thing.
Old Sep 5, 2008 | 03:50 PM
ri_truck_guy
Nah...the wiring is the same...I just put a donor column from a C6 in my AOD truck about 5 months ago and everything plugged and played just fine. It would be completely contradictory to everything Ford did with plug and play harnesses if the column wiring were different. What they may be talking about is the subtle differences bewteen ignition switches in different year trucks, but I've never heard of that difference causing a truck not to run either.
Old Sep 5, 2008 | 03:51 PM
ri_truck_guy
The only swap I haven't tried is putting a diesel column in a gas truck, but by the wiring diagrams even they are the same.
Old Sep 5, 2008 | 08:49 PM
GLR's Avatar
GLR
Hey Cliff, where is that U pull it located? I'll need a place to escape to when I get back to VA. Thanks, George
Old Sep 6, 2008 | 12:10 AM
SuperSnake's Avatar
SuperSnake
It's in Greensboro,NC. Which is a long drive.
We also have one already open In Charlotte and will soon have one open in Winston Salem. Pull A part.
Link for Pull A Part: Pull-A-Part
Old Sep 6, 2008 | 12:11 AM
SuperSnake's Avatar
SuperSnake
The engine was out of a 86 Bronco so I guess it had a EFI 302 the engine was gone from it.
Old Sep 8, 2008 | 07:30 AM
GLR's Avatar
GLR
There's also 109 u-pull-it near Winston. Need any thing special? I'm going to check out one here in NY this week. I hate to go there because I usually end up with a truck full of "must have" goodies.
Old Sep 8, 2008 | 11:32 AM
polarisman729's Avatar
polarisman729
Which one in NY are you going to? I was recently at thje Pick-N-Pull in Auburn and there is some good stuff there i'm gonna go grab.
Old Sep 8, 2008 | 12:04 PM
  #28
SuperSnake's Avatar
SuperSnake
GLR Check this Pull A Part.This one is suppose to open in Winston in Oct Super prices.
Pull-A-Part
Old Sep 8, 2008 | 12:06 PM
  #29
SuperSnake's Avatar
SuperSnake
Going to U pull it again tomorrow to grab some more parts,like a 80 grill,hitch,cigarette,lighter and a couple more things.
Old Sep 8, 2008 | 04:28 PM
  #30
GLR's Avatar
GLR
Hey Polarisman, went to college in Oswego, had fun during the 66 storm. I usually go to the Horseheads pick-a-part. They usually have a better selection than Auburn.
By Verdad Gallardo | 2026-06-03 11:38:19
