1978 - 1996 Big Bronco
What differential do I have?
Old Sep 4, 2008 | 09:55 AM
poffutt's Avatar
poffutt
I have a 89 EB 351. My bearings went out on the front driverside wheel. The inside bearing racer has seized it self to the spindel. I am on Broncograveyard trying to locate a spindel and I need to know what front differential I have. Can anybody tell me?
Old Sep 4, 2008 | 10:15 AM
alxsnmr's Avatar
alxsnmr
Should be the Dana 44 TTB.
Old Sep 4, 2008 | 10:39 AM
poffutt's Avatar
poffutt
Thank you very much.
I found the part for 120 with shipping. The ford company wanted $600 for it and Oreillys wanted 150 for it. Graveyard won!
Old Sep 4, 2008 | 11:00 AM
NWBronco's Avatar
NWBronco
You can also try...
Welcome to Complete Off Road
Mike's pricing has always been pretty decent.
Old Sep 17, 2008 | 12:50 PM
dblake37's Avatar
dblake37
I have had the same problem a time or two. I found a good one at a junk yard where you pull the parts off yourself and only paid about $10 for it. another time I cut a grove in the bearing and was able to break it off. I cut it almost all the way through and hit it with a hammer a few times and it came right off. Don't know if that was a good idea but I had to get to work in the morning and the bronco was all I had.
Old Sep 17, 2008 | 01:01 PM
uncle.stosh's Avatar
uncle.stosh
I can get you a used one way cheaper.
Let me know. I'm at the salvage yards every day.
Old Sep 18, 2008 | 03:28 PM
poffutt's Avatar
poffutt
So how long has it been working for you? I have added the new spindle to my truck and now started having problems with the other side. Found out it is the spindle bearings. So i am thinking of spliting the frozen bearing on the old spindle like you did and see if I can use the old one I still have.
Old Sep 22, 2008 | 10:24 AM
dblake37's Avatar
dblake37
It has been fine for about 4 years now. I don't drive it much anymore. I have found that the best thing to do is avoid deep muddy water, but I know it's hard.
Old Sep 30, 2008 | 01:23 PM
Bronco308's Avatar
Bronco308
I had the same thing happen many years ago to my '71 Mustang; i used a propane/butane torch to heat the race and get it off the spindle. polished the spindle with emery clothe, put a new bearing on it and ran it for years.
Old Oct 9, 2008 | 07:45 PM
hodernyf150's Avatar
hodernyf150
what side do you need i have one for a dana 44 ttb axle
