Starter weirdness
Old Sep 3, 2008 | 09:36 PM
rbpems's Avatar
rbpems
Starter weirdness
When I turn the key to start, most times I have to turn the key two or three times for the starter to trigger. Has this happened to anyone else? I'm not sure where to start, no pun intended.
Old Sep 3, 2008 | 10:39 PM
ford trans tech's Avatar
ford trans tech
you need to replace the ignition switch , this is common wear issue
Old Sep 4, 2008 | 10:24 PM
Dave Sponaugle's Avatar
Dave Sponaugle
Clutch or automatic tranny?
Old Sep 4, 2008 | 11:08 PM
rbpems's Avatar
rbpems
Thanks for the replies. It's a 93 E350 NA auto, 282,000 miles. I might actually prefer a manual in this truck but I don't think the vans got them. If I need to replace the ignition switch, you mean the cylinder in the stearing column, right.
Old Sep 4, 2008 | 11:53 PM
ford trans tech
not the cylinder , the switch is mounted on top of the mast jacket under the dash
it is retained with two screws
Old Sep 5, 2008 | 05:07 AM
FORD MEGA CAB!!!'s Avatar
FORD MEGA CAB!!!
Not to confuse you but also, Do you hear any clicking when you turn it to the start position when it doesn't crank. If you do hear a lound click when you turn the key, You probably have a bad solonoid either on the right fender well or the starters solonoid. You can have someone listen to the one on the right fender and if see if it clicks when you turn the key when it won't start. If so, Post for more info. If no clicks at all, Then I would agree to start at the switch.
(Also, Im not sure where the starter relay is on the van)
Old Sep 5, 2008 | 09:10 PM
rbpems's Avatar
rbpems
I don't hear any clicks. When I turn the key the glow plug light comes on as usual, when it goes out I turn to the start position and there's nothing at all. If I hold it in the start position for a few seconds or try one or two more times it will crank like it should. I'll replace the ignition switch and see if that fixes it, if not it sounds like I should look at the solenoid. There's one on the starter is there a second under the hood?
Old Sep 5, 2008 | 10:27 PM
Dave Sponaugle
Wonder if the neutral interlock is causing your problem?
Next time it does this try moving the gear selector and see if it starts.
