Sponsored by: Kumho
Bleeder screw question
Old Sep 3, 2008 | 06:37 PM
GloryToTheSouthland's Avatar
GloryToTheSouthland
If i loosened the bleeder screw on a 1987 Bronco II to where fluid could run out how many times would the brakes still work before going to the floor. No worries here on me doing this its an argument with someone else.
Old Sep 3, 2008 | 07:16 PM
andym's Avatar
andym
Depends how much fluid is in the master cylinder reservoir.
Old Sep 3, 2008 | 07:20 PM
quaddriver's Avatar
quaddriver
divorce southern style?
Old Sep 4, 2008 | 06:48 AM
srercrcr's Avatar
srercrcr
Since the screw is open and fluid runs out you have no pressure, hence the answer is zero.
Old Sep 4, 2008 | 08:18 PM
Gevans17's Avatar
Gevans17
no pressure = no brakes..doesnt matter how much fluid is in the reservoir.
Old Sep 5, 2008 | 10:28 AM
andym's Avatar
andym
Yeah, you're right. Didn't read the question carefully enough I guess.
Old Sep 5, 2008 | 03:05 PM
srercrcr's Avatar
srercrcr
When you bleed the brakes you'll learn that as soon as the bleeder is opened the brake pedal will go to the floor.
