Radiator Support
Old Sep 3, 2008 | 04:41 PM
rmalottwtes30's Avatar
rmalottwtes30
Radiator Support
Does anyone have a picture of a radiator support out of a 1992-1996 Diesel. If not how about a picture of how the radiator mounts up to the core support?
I own a 85 f-250 diesel and hope to install a 92-96 front clip on it but want to do some research to find out what needs to be changed. Thanks
Old Sep 3, 2008 | 06:07 PM
N8N's Avatar
N8N
OK, I have to ask... WHY? IIRC an '85 would have sealed beam headlights, the plastic headlights in my '93 suck and what's worse is when I'm driving my car I can always identify a similar year truck because it's the one that's blinding me with all the glare from the headlights.
nate
Old Sep 3, 2008 | 06:57 PM
rmalottwtes30
nate
I just like the looks that year/model front end...
Old Sep 3, 2008 | 07:47 PM
lostin90s's Avatar
lostin90s
Basically the center section is cut out . If u have no turbo u can modify a gas one.a
Old Sep 3, 2008 | 07:51 PM
N8N's Avatar
N8N
OK, I can respect that, but still... I'd do a lot to get rid of those awful headlights and have the ability to swap in some E-codes. Now if you are near me and think it'd work, I've got a '93 F-150 with a 300 and if that clip would work for you c'mon over and let's swap.
nate
Old Sep 3, 2008 | 08:05 PM
rmalottwtes30
Cincinnati Ohio here N8N. Well You say I can use one from a gasser? All I got to do is a little mod? Do you know what exactly it would be Id have to do?
Old Sep 3, 2008 | 08:23 PM
N8N's Avatar
N8N
no, I have no idea if it'd work or not, I was just saying that I'd be open to do the swap the other way (older clip on newer truck.) I'm only, oh, about 500 miles from you tho so might not be practical...
nate
Old Sep 5, 2008 | 05:13 PM
lostin90s's Avatar
lostin90s
How little the mod is I cant say . But both look same other than center section opening is way bigger.
