Offroad & 4x4
Trasfer Case Motor
Old Jan 17, 2003 | 01:01 AM
Putz's Avatar
Putz
Trasfer Case Motor
Heres one guys, in the Ranger forums they told me to try here, So here it is my trasfer case motor, when I swtich it to 4H, it goes to the position but kicks right in reverse and goes back to 2wheel drive, ANY IDEAS, I have reaplaced the motor twice, Any Ideas would help, Thank you much all
Old Jan 17, 2003 | 07:54 AM
steve83's Avatar
steve83
Trasfer Case Motor
http://www.glue.umd.edu/~singletn/web/pages/tcase.html
Old Jan 17, 2003 | 01:22 PM
77fromheaven's Avatar
77fromheaven
Trasfer Case Motor
Old Jan 18, 2003 | 10:37 PM
pavelow's Avatar
pavelow
Trasfer Case Motor
have you reset your shift module? If you have a haynes manual it tells you how to do it.
I would even try disconnecting the battery for a few minutes and hook it back up and reset the computer. It may be a dumb computer glitch. Try the easy stuff first, then move on to the bigger stuff.
Old Jan 20, 2003 | 05:06 PM
MEPR's Avatar
MEPR
Trasfer Case Motor
Start simple like reseting the computer. Then i would try checking the t-case fluid level, you never know what dry gears can do. And if the level is good then see if there are any metal shavings in it, if the fluid is low thats probly your problem.
bigcrunch
May 17, 2013 07:41 PM
Bigcountry102
Sep 26, 2012 08:40 PM
D Kenney
1983 - 2012 Ranger & B-Series
Oct 25, 2009 01:09 PM
littlefuzz
Apr 20, 2009 06:37 PM
hammerdn
Sep 11, 2002 12:23 AM
