I own a 1987 F-150 2-wheel drive with an inline six and manual transmission(4-speed,actually a three with a granny gear)I purchased the truck new in '87 and currently have a little over 88K miles on it. A couple of years after I bought it I jump started a man and have had problems ever since. I had to replace the alternator,battery, starting relay just to name a few. I have not been able to pass the emissions test for the last several years,if I spend $200 trying to fix it they'll give me a wavier to get my tags renewed. Starting to get too expensive. The truck runs strong at higher RPM's. It has a miss at lower revs and is noticeable when driving around 35 to 45mph. I have had the timing checked and reset on several occasions but no help. Local Ford dealer can't find anything wrong. I don't have much confidence in them, if it doesn't show up on their diagnostics they just quit looking. Is there a way to check the ignition module and could I have damaged the computer chip by jump starting someone? I apologize for the length of this message but I failed the emissions test again yesterday. I hope to someday solve this problem and if anyone can offer advice I would greatly appreciate it. The part of the emission test that I fail is the Hydrocarbons. Thank you in advance for any and all help.
I was wondering if any one tried a new MAP sensor on your truck ? Another concern would be the TPS or it's adjustment.Both of these sensors tell the computer the load of your engine and adjusts fuel/spark accordingly.Also, you may try a new coolant temp sensor {not the guage sendor} to insure a good fuel to air ratio while idling which could be your e-test problem.
Phillip
I have had a new MAP and TPS installed for almost a year with no improvement in performance or emissions. Truck has been in the shop this week and a scan showed the EGR control solenoid was defective. I wasn't surprised since I have been driving for a year with that vac. lined plugged with a golf tee.
Waiting on parts at the moment. Could the EGR valve make that big a difference in the emissions readings? If this doesn't help is there a way to check the ECM itself?
You bet it'll throw off a reading,especially if the tech juices the throttle a couple of times to see what happens to the readings. depending on the design itself,some will open on there own at a certain backpressure in the exhaust,but all are designed to be closed off at idle{no vacuum applied}You may solve your "miss" problem after you get the EGR system working properly because these things you just can't plug up on a fuel injected vehicle.
phillip
Phillip, thanks for your help but that didn't cure my problem. EGR valve sensor and solenoid have been replaced. Headed back to shop Monday
for further checks. Let you know later
