Almost Ready to Fire
Old Sep 2, 2008 | 08:38 PM
cts1954's Avatar
cts1954
Just a few more minor details and this guy is ready to fire. Question - specs say the 239 hold 23 quarts of coolant, I know the answer to this if I lived in California but what is the proper mixture for antifreeze. I figure maybe 70 %.
Old Sep 2, 2008 | 09:28 PM
52merc's Avatar
52merc
I think you want a 50/50 mix. I know with glycol antifreeze if you go much more than 50 or 60% glycol the freezing point of the mixture actually goes up.
Old Sep 2, 2008 | 11:04 PM
jm ray's Avatar
jm ray
looking mighty fine from here. wish we all could come up to hear it purr
Old Sep 2, 2008 | 11:07 PM
Old F1's Avatar
Old F1
Hummmmmmmm. Nice lookin’ new engine. If it was me I would start with just water and some water pump lube and / or block seal (bars leak does both). Warm her up a couple of times and check for any possible leaks, just in case. Antifreeze is nasty stuff if it goes into the wrong places. 50 / 50 mix is standard, good for -34 f.
“but being wrong keeps me humble”
Old Sep 3, 2008 | 03:08 AM
ALBUQ F-1's Avatar
ALBUQ F-1
Nice engine! What heads are those?
Old Sep 3, 2008 | 07:31 AM
cts1954's Avatar
cts1954
Thanks for the info, I will start with water then go to a 50/50 mix.
Heads are made by Schrager Automotive Engineering, vintage 50's manufacturer. I have not been able to find out anything about them other than they may have been around the Chicago area. Anyone ever heard of them. They were in good shape when I got them, a few pits that I had filled, had them checked and ground flat. Had to open up the valve cavities for my high lift cam by hand and that was alot of work but I am hoping they work OK. I have had the engine running with the stock intake and carb and ignition and all seemed to be good, next step is to run it with the dual Strombergs and stock ignition, then go with the electronic ignition.
Thanks for your comments
Old Sep 3, 2008 | 07:58 AM
bobbytnm's Avatar
bobbytnm
Roast em' if you got 'em
Wow, thats a beauty!!
Good luck on getting her lit off. A 50/50 mix will do for most applications
Bobby
Old Sep 3, 2008 | 11:10 AM
cmoritz's Avatar
cmoritz
I agree on the 50/50 mix and that looks like a HotRod Flattie, Cool stuff! Good Luck!
Old Sep 3, 2008 | 12:18 PM
Mercury Bluz's Avatar
Mercury Bluz
Good looking engine cts1954!
I would agree with the concenus on a 50/50 mix.
If you want/need any help let me know I'm located just south of you on Rice Lake.
john
Old Sep 3, 2008 | 07:44 PM
Mick1930's Avatar
Mick1930
CTS..as you know straight water is the best for thermal transfer. If you are just ready to get it going I would use straight water and some water wetter. Wetter will help reduce the block surface tension and help lubricate the pumps. Then as you work all the bugs out and thing get closer to winter use a 50/50 blend with Sierra. Sierra does not foam or froth in these engines. I redid a sweat 37 and had stock water pumps..but mine where on the heads as yours are on the block. But they leaked..because I had a new waker radiator and a 15lbs pressure cap. That was my problem as the 37 flathead does not have a pressure system and it pushed water out of the packing. I did not figure this out until I was relpacing my second pump. So not sure about your later engine and water pumps but you may want to give that aquick investigation.
flatheads forever..very nice.
Old Sep 3, 2008 | 08:24 PM
cts1954's Avatar
cts1954
That brings up another question about coolant, the manual says it holds 23 quarts, I am assuming that is an American quart not an Imperial quart. We deal with litres up here and it is almost the same as a US quart. As in the oil capacity I have just put in 5 liters of oil and it looks low on my Lokar dipstick but it could be wrong.
Old Sep 3, 2008 | 09:16 PM
Dustin1690's Avatar
Dustin1690
Ooh looks great best of luck for the first fire
Old Sep 4, 2008 | 02:59 PM
petey shoes's Avatar
petey shoes
yes, american. 1 gal. =4 qts. -so 3 gal. antifreeze, 3 gal. water. stagger fill process. 1 gal. anti.-1 gal. water, etc.on third gal. of anti. only put 1/2, then 1/2 water until full. remember to leave room for expansion. if water pumps are stock, then system SHOULD be low pressure. 4-7 lbs. wetter is a very good suggestion simply because engine is beefed up, so more heat, not only that, it works. probably a 180 thermostat, to start.----- LOOKS REALLY GOOD< NICE JOB!!!!!!
Old Sep 4, 2008 | 03:22 PM
Mercury Bluz
1 U.S. quart = 0.946352946 litres
therefore
23 U.S. quarts = 21.7661 litres
GBTUNDRAQUEEN
S. California Chapter
Nov 19, 2013 11:31 AM
FP
97
May 28, 2013 07:57 PM
oneill
Flathead V8 & Flathead 6
Jul 19, 2011 02:59 AM
StretchRcr
Car/truck Buying Advice
Mar 14, 2005 03:26 PM
Old Chief
Dec 14, 2004 11:18 AM
