Auto Trans Cooler
Old Sep 2, 2008 | 07:43 PM
bkuuz1's Avatar
bkuuz1
Auto Trans Cooler
Anyone using the 10,000lbs auto, trans cooler from Napa? What kind of results are you having with it?
Old Sep 2, 2008 | 07:50 PM
danskool's Avatar
danskool
Go Bills !
I almost brought one. But folks on here like the TruCool. That is what i am saving up for now. http://www.dieselsite.com/index.asp?...ROD&ProdID=205
Old Sep 2, 2008 | 07:52 PM
UP_There's Avatar
UP_There
get a bigger one.....I've got the Ultra Cool, and I'm not sure what the rating is......but I believe it's like 60,000? Get the biggest one you can! They aren't much more expensive, and it's money well spent
Old Sep 2, 2008 | 07:53 PM
mueckster's Avatar
mueckster
The Trucool 4739 Max is also a 40k cooler vs the 10k Napa.
Old Sep 2, 2008 | 07:54 PM
UP_There's Avatar
UP_There
Tru-Cool is definitely the most popular, but the results are the same......they are both effective. The Ultra Cool has pretty much the exact same specs and it's about $80 cheaper
Old Sep 2, 2008 | 08:11 PM
danskool's Avatar
danskool
Go Bills !
Interesting, I forgot about ultracool
Was the mounting better than the trucool? Fittings?
Old Sep 2, 2008 | 08:48 PM
mueckster's Avatar
mueckster
Hayden Ultra Cool (tube and fin Design) is rated 26k. Hayden Transaver Plus is rated 30k. These were the largest I have seen in these models.
Old Sep 2, 2008 | 09:34 PM
UP_There's Avatar
UP_There
Honestly.....I think the BD Cooler is better then the Ultra Cool, Tru Cool or the Hayden, it's got a built in fan
Old Sep 2, 2008 | 10:20 PM
bkuuz1's Avatar
bkuuz1
Thanks for all the replays, I actual already have a BD Cooler mounted under the truck on the right side. My trans temp run 160F to 185F on a 85F day. Pulling my 5th wheel it will run average 185F on the freeway but when pulling at slow speeds up the dirt mtn roads it will get up to 200F to 250F. It really scares me when it gets in the higher temps. I think I will move the BD Cooler behind the grill to get more air flow through it.
Old Sep 2, 2008 | 11:29 PM
UP_There's Avatar
UP_There
Once you move that BD cooler up front......you won't have any cooling problems at all, save your money for another mod!
