2003 expedtion problem
Old Sep 2, 2008 | 03:45 AM
tsmars's Avatar
tsmars
On my 2003 expedition 4.6 liter, when i turn on the a/c it trys to stall,(but never has)and i can hear a pump sound(smog pump?)idle is all over the place.shows no codes..anybody have any thoughts?
Old Sep 10, 2008 | 02:59 PM
Frat-man-du's Avatar
Frat-man-du
Only with the A/C on? Does it run OK the rest of the time? Does the A/C get cold?Does having the rear A/C on matter?
Old Sep 10, 2008 | 09:04 PM
alloro's Avatar
alloro
I would say your AIC valve is either dirty or just outright bad. There are many threads on here you can search for that deal with cleaning the valve.
Old Sep 10, 2008 | 11:03 PM
tsmars's Avatar
tsmars
A/C is cold,rear air works great...i will look into the AIC..thanks for your help
Old Sep 11, 2008 | 12:49 AM
Monsta's Avatar
Monsta
Sit. Stay.
You should inspect the PCV (Positive Crankcase Ventilation) and the associated hose for cracks. Pull the valve and plug the hole with your finger with the engine running. If idle improves, you have a bad PCV.
Old Sep 11, 2008 | 01:21 AM
tsmars's Avatar
tsmars
thanks, I will check that also..
dustys7.3psd
Feb 11, 2019 08:03 PM
gonzales
1997 - 2003 F150
16
Jan 6, 2017 09:25 AM
postmaster12
Mar 3, 2016 10:55 AM
MDSLIGHT
Nov 1, 2015 10:08 AM
