7.3 Diesel Glow plug controller/water temp interference?
Old Jun 11, 2000 | 03:09 PM
crewcab_1's Avatar
crewcab_1
Ok, I know you electrical geniuses will get this one easy.
1990 Crewcab 7.3 with ATS turbo 40,000 on engine(yes, 40K).
All of a sudden the water temp goes full hot (all the way to the peg as if shorted), the engine lite comes on, and burning plastic smell. Checked under the hood, and the glow plug controller bowas moved to the left valve cover to make room for the turbo)is hot and ground wire to it was smoking.
Note: engine was not really hot, just reading that way.
Removed glow plug controller and cleaned all contacts, replaced ground wire terminal, and re-installed. At the turn of the key, it still sends the engine lite on and the temp guage to full hot intermittantly, but the two large ground wires dont get hot now. The controller clicks on and off rapidly at times causing the water temp to bounce. I have replaced the thermostadt and the temp sender just to be sure.
I hate to spend 160 dineros if the controller is not the problem. Why is the water temp interacting with the glow plug controller and the engine lite?
Any help is highly appreciated.
This one is twisting my brain pretty hard.
Thanks!
Old Jun 15, 2000 | 07:41 PM
audredge's Avatar
audredge
hturner12
Jan 19, 2015 05:39 PM
Metz12345
Jan 19, 2015 06:48 AM
cdv10
Jun 6, 2011 02:17 PM
Scottie250
Nov 15, 2006 09:11 PM
kenf1948
Jun 5, 2001 11:23 AM
