Sponsored by: Real Truck
Hydro Boost
Old Sep 1, 2008 | 06:28 PM
hazmic's Avatar
hazmic
Hydro Boost
Has anyone had to replace the Hydro Boost?, How much was the part? Also how hard? Mine is leaking around the seal inside the cab.Mine is a Super Duty F350.
Old Sep 2, 2008 | 03:58 PM
krewat's Avatar
krewat
FTE Leadership Emeritus
BUMP! Anyone?
Old Sep 2, 2008 | 04:48 PM
danyzf95's Avatar
danyzf95
about 200 bucks.mine engaged the brakes all of the time.it takes about an hour to change. not hard to do. pretty straight forward when you take it apart. Loosen the two nuts on the mater cylinder and slide it forward. Unhook the brake pedal and a few miscellaneous fasteners and brackets.
Old Sep 2, 2008 | 05:10 PM
hazmic's Avatar
hazmic
Thanks for the info. I put some seal condtioner from LUCUS and will wait and see if that helps and if not Looks like we will be changing it.
