water pump
Old Aug 31, 2008 | 10:06 PM
indebt's Avatar
indebt
water pump
check this out found out why my coolant is always low
Old Aug 31, 2008 | 10:08 PM
Mike Norwood's Avatar
Mike Norwood
Glad you found it, but you don't have to replace your water pump to fix that.
jdecker88's Avatar
jdecker88
That would be a good reason why Jorge heh, never noticed any on the ground? There is a great video on youtube about doing the waterpump change ont hese trucks.
Old Aug 31, 2008 | 10:12 PM
indebt's Avatar
indebt
coolant never made it to the ground. After I searched, it was all on the lower radiator hose and would be gone before it accumulated enough to hit the ground. Oh well I think after seeing what my brakes were like I am gonna just do the water pump and flush and 203* stat
Old Aug 31, 2008 | 10:14 PM
indebt's Avatar
indebt
What are you thinking on this Mike? I think I wont get around to it for a while anyway. Maybe I can check and retighten the bolts?
Old Aug 31, 2008 | 10:18 PM
Mike Norwood
Unless I'm wrong, it looks like it is leaking from around that seal where the thermostat housing mates up to the water pump. That is just a form-a-gasket/silicone seal. Those three bolts take off the thermostat housing, just clean it up real good and use some good RTV silicone and you should be good. Unless you specifically buy a water pump that has a thermostat housing with it you have to re-use your old one anyway.
Old Aug 31, 2008 | 10:20 PM
indebt's Avatar
indebt
Maybe I'll just do a flush and "fix it" then. Thanks.....
Old Aug 31, 2008 | 10:23 PM
Mike Norwood
No problem, I have replaced my water pump twice and had to re-use the housing(the first water pump was defective). Good luck on yours.
Old Sep 1, 2008 | 05:16 AM
ron's power stroke's Avatar
ron's power stroke
YouTube - Water Pump RnR
Old Sep 1, 2008 | 06:00 AM
Alpine6's Avatar
Alpine6
Get the billet Diesel Site housing and 203 Stat. The stock housing is pot metal and deforms and pits easily. Becareful with the 3 tiny bolts holding the housing on. They break easily because of the corrosion.
