H62 Code What Does It Mean?
Old Aug 30, 2008 | 04:57 PM
BMWM1's Avatar
BMWM1
Question H62 Code What Does It Mean?
Ive been researching my truck to find out exactly what is in it.What does the H62 code mean.I have found several answer but they were different.Here is what threads I found on this subject.I thinking it is 3.50 gearing with limited slip front anyone here can confirm this?
https://www.ford-trucks.com/forums/3...-code-h62.html
https://www.ford-trucks.com/forums/3...and-axles.html
Old Aug 30, 2008 | 05:24 PM
IcemanV8's Avatar
IcemanV8
In my 1986 manual, there is no H62. But there is an H6, and it is 3.50 ratio. Is the tag still on your rear end? It will tell you.
Old Aug 30, 2008 | 05:54 PM
BMWM1's Avatar
BMWM1
Thanks for the help.Ive just returned from under the truck.
H62 number was found on the door jamb
Differential is from Jasper.It is stamped 3.50 Ratio
Transfer case 2.61 Ratio Model 208F
Transmission E0TA700RFE25 UNDER THAT IS 435
12/7/81
Im trying to get all of this sorted out so I can redo the brakes.Its nice to know what your dealing with.
Any input would be appreciated.Thanks
Old Aug 30, 2008 | 08:33 PM
rhodie's Avatar
rhodie
The "H" part means it is limited slip.
Old Aug 30, 2008 | 09:51 PM
BMWM1's Avatar
BMWM1
From what I have found the 3.50 ratio uses a different rotor then any other F-150 setup.Can anyone confirm this for me?
strokin'_tatsch
76
Jun 15, 2018 05:27 AM
Stewart_H
Oct 24, 2017 11:57 AM
aortizexcursion
Feb 21, 2012 06:08 PM
Fomoko1
24
Mar 20, 2007 09:12 AM
