ABS Light
Old Aug 29, 2000 | 07:57 AM
ET2's Avatar
ET2
ABS Light
The ABS light in my 1990 Bronco (with rear ABS only) stays on constantly. I turn the truck on, it lights up, goes out for a second then comes back and stays on. The brakes are fine. Anyone had a similar problem?
1990 Bronco XLT, Skyjacker 6" Suspension Lift, Rancho RS-9000 Shocks, Super Swamper Thornbird 35x12.5R15s, 400HP 351
Old Jan 9, 2001 | 08:10 PM
millergldblk's Avatar
millergldblk
ABS Light
I am sure your not to worried about spending money on the ABS for
a Fourwheeling truck
A quick fix that I've done to several Rangers, Bronco's, F-pick-up with RW ABS is a piece of electrical tape over the light
Old Jan 9, 2001 | 10:21 PM
nitro94's Avatar
nitro94
ABS Light
Usually its the sensor located on top of the rear end.
2000 XLT Flare Supercab Sport 5.4-Auto-355LS-Tow pkg-Bedrug-Xtang Tonneau
Old Jan 11, 2001 | 07:11 PM
Mulletwagon's Avatar
Mulletwagon
ABS Light
A common problem is for the ABS computer to loose ground. There are two pigtails on the negative battery cable - one is to ground the EEC and the other is to ground the ABS. The problem is a two prong connector next to the battery by the radiator support. Corrosion in the connector often causes intermittent ABS and EEC failure. Worth checking.
Old Jan 12, 2001 | 02:40 PM
bill russis's Avatar
bill russis
ABS Light
Trigger1911
Jun 10, 2023 05:07 PM
justcruzin125
17
Mar 1, 2016 06:44 PM
gateway1
1978 - 1996 Big Bronco
Jan 12, 2006 06:05 PM
westladog
Oct 25, 2005 06:47 PM
scarletaz
Sep 1, 2004 07:14 PM
