I had the same problem with my truck. All I did was I rewired the whole light assembly and then played around with the shifter to knock anything loose or get the connection working and now they work. They will sometimes cut out but I just have to shake the shifter and it comes back on.
Hope that helps.
Gary Warrick
If a Chevy's runnin good its gotta be FORD under the hood!! :~Þ
is it auto trans or manual or what ? no doubts its a bad switch on the tranny or a broken wire somewhere, copper wire rots and here in wisconsin with all the snow and salt exposed connections underbody go bad real quick
