ive got a 1990 4&4 that has a odd transfercase problem when in 4&4 high its ok but when in 4&4 low it seems to still be in high gear the 4&4 low light is on how is this possible the trans is a auto any ideas thanks
the light is essentially triggered by the linkage being in the right place. can you get into neutral? It is impossible to go 2H->4H->N->4H so try it again
the shifter works fine goes into n 4h 4l 2h no problem im wondering in the case is there maybe a slide thats thats not moving out of high when shifted to low i just bought the truck when going through the truck i found the case empty of oil this may mean that the guy was inside the case or knew of the problem but sait nothing
I checked again its in 4 high no matter where you put the shifter if you put it in neutral its still in high if you put in 4 low the low light comes on but its still in 4 high thanks
